Distributor slop
Old Nov 13, 2008 | 07:33 PM
leskinner's Avatar
leskinner
Default Distributor slop
Hi guys-
I'm getting ready to install the HEI dist. into my newly rebuilt 383 and noticed the dist shaft has .062" end play. Seems like this would screw up any attempts at setting timing. Is this OK or do I need to shim and if I do, to what clearance ? Or, do I toss it and find a better one. My original has over 100,000 miles on it.
TIA
Larry
Old Nov 13, 2008 | 09:14 PM
stingr69's Avatar
stingr69
buy a pack of distributor shims and set it at .015" or so. I think some people set them as tight as .007". Not a big deal.
-Mark.
Old Nov 13, 2008 | 10:09 PM
leskinner's Avatar
leskinner
Thanks for the info Mark. Any idea where I might get shims ?
Larry
Old Nov 13, 2008 | 10:10 PM
ksbunting's Avatar
ksbunting
Stingr69 is right.
This is extremely easy to do. I did mine at .010 for my 68.
Quick job and no special tools required.
Kurt
Old Nov 13, 2008 | 10:36 PM
...Roger...'s Avatar
...Roger...
.010-.015 for aluminum distributors.Dont forget to align the gear dimple with the rotor contact.
Old Nov 13, 2008 | 11:08 PM
TimAT's Avatar
TimAT
Mr. Gasket or Moroso. any parts store should be able to get them or you can mail order from just about any of the Hot Rod parts stores.
Old Nov 14, 2008 | 12:31 AM
leskinner's Avatar
leskinner
Thanks Everybody !
I will try local parts stores tomorrow.
Larry
To Distributor slop
