Engine decodes
Old Nov 15, 2008 | 04:28 PM
TyCor's Avatar
TyCor
Default Engine decodes
About 10 months ago I logged onto the forum and asked how to decode my engine as it was not the original. But I never could get a definitive answer...Now I have some numbers off the heads, I though maybe this might help.
Block #: 3970010
Drivers Head: 3999699
Pass HEad: 3886388
I am really just interested in if I have a 327 or 350.
Old Nov 15, 2008 | 04:35 PM
Durango_Boy's Avatar
Durango_Boy
Were there any other markings or date codes on the heads? Neither of those casting numbers are listed on Mortec and that's usually a pretty good site for finding this information out.
Did you have the code from the front pad on the block?
Old Nov 15, 2008 | 04:39 PM
TyCor's Avatar
TyCor
I got the head numbers from the front pad, after I pulled the valve covers off...where else should I look if those numbers are not right?
Old Nov 15, 2008 | 04:46 PM
razman's Avatar
razman
you have a 350 cu in block (original configuration anyway, could have been bored or stroked by now)
we could tell more if you could get the numbers from the front pad. (just below the head on the right front of the engine) next to where the water pump bolts on. rick
Old Nov 15, 2008 | 07:28 PM
TyCor's Avatar
TyCor
OK..I just checked near the water pump and found that someone at one point had chipped the paint off and exposed this number:
V0710OMA18D4241 _ _ there maybe two more numbers on the end, but I can't read them.
Old Nov 15, 2008 | 09:21 PM
TyCor's Avatar
TyCor
Anyone shed some light on these engine codes? I was told when I bought the car that it had a 327. and the guy selling it had a '68 vert also in his garage. He got both cars as payment for some type of service his company did for a customer. He was not into vettes, and just wanted to get the cash out of them.
Old Nov 16, 2008 | 09:50 AM
Duke94's Avatar
Duke94
The block casting number could be either a 327 or 350.
No listing for the head castings. Is there a 2 or 3 letter engine code on the block data stamp pad?
http://www.mortec.com/castnum.htm
Old Nov 16, 2008 | 10:25 AM
Mike Ward's Avatar
Mike Ward
As others have said it could be a 327 or a 350. The V0710OMA will narrow it down further.
V is for Flint Michigan ***'y plant. 0710 is the date of assembly. July 10.
The next three letters will determine what engine type it is. Are you sure it's OMA? Maybe CMA?
Old Nov 16, 2008 | 02:59 PM
razman's Avatar
razman
well, i learned something new! i never realized that GM made any 327 engines with the 010 casting. i always thought most of them were the 870. thanks guys, rick
Old Nov 16, 2008 | 03:32 PM
stingr69's Avatar
stingr69
GM never made 327 production cars with the "010" block. You could use a "010" block to build one yourself if you had a 68-69 large journal 307 or 327 crank but there isn't any way to tell without tearig something apart to see it.
Based on the casting number, the only factory build would be a 350.
-Mark.
Old Nov 16, 2008 | 04:27 PM
Mike Ward's Avatar
Mike Ward
Originally Posted by stingr69
GM never made 327 production cars with the "010" block. .
I have seen listings for a '68 327 installed in Chevelle/El Camino cars using the 0010 block. Not saying that it's right though.
Old Nov 16, 2008 | 06:42 PM
TyCor's Avatar
TyCor
Mike,
what if those three letters were CMA vs. OMA...what would that mean? The numbers/letters are really faded.
How many numbers whould there be....I'll go try again.
Old Nov 16, 2008 | 07:43 PM
stingr69's Avatar
stingr69
Mike,
That is probably just a careless assembly of information by the author. You have multiple different SBC block castings being used in 1969 but they were not all being used at the same time.
The 327 engine was discontinued by Chevrolet in February 1969 and replaced by the 307 which uses a different block casting. The ".010" blocks weren't being cast before April 1969 so I don't see where we could get a factory built 327 with that "010" block unless I am missing something.
-Mark.
Old Nov 16, 2008 | 11:44 PM
Mike Ward's Avatar
Mike Ward
-Mark.
No, I think you're right. Bad info on a web site.
Old Nov 16, 2008 | 11:47 PM
Mike Ward's Avatar
Mike Ward
Mike,
CMA would be 1974 350 turbo hydro trans. 2bbl carb A B F X body
Much more likely.
O can frequently look like C and vice versa.
To Engine decodes
