ck eng light
Old Nov 16, 2008 | 04:28 PM
mich4u33's Avatar
mich4u33
Cruising
Default ck eng light
Hey all I have a 81 L81, my ck eng lite keeps coming on. My codes are 23 and 51, 23 is with my Carb MC Solenoid and 51 is the ECM/PROM. It did some cks from the manual, it leading to replacing my ECM. The Quad Jet is the Org Carb. I cked all the wires leading to the solenoid and the ECM, no problems. any ideas? my email is mich4u33@yahoo.com.
Old Nov 16, 2008 | 06:51 PM
7T1vette's Avatar
7T1vette
Before you change parts, disconnect all connectors and grounds, clean them well and reinstall. You may just have a tarnished connector terminal or a weak ground. If you do this and then you still have the same codes, then you can try part swaps/changes.
