Daytime Running Lights (DRLs)
Old Nov 16, 2008 | 05:39 PM
Paul L's Avatar
Paul L
Default Daytime Running Lights (DRLs)
Just a thought this afternoon as I watch some snow come down and plan my winter projects. A couple of years ago I converted my 1967 (now sold) to DRLs. The kit basically allows for running the front park lamps on the bright (turn signal) filaments of the 1157 bulbs while driving. This is a safety feature as it enhances your visibility to oncoming drivers; particularly important on two-lane roads where people are prone to take risks when passing. The Corvette has a low profile and is not terribly visible to those risk-takers.
The DRLs are ignition-switched to be on when the car is running. Your can defeat this if you wish with a toggle switch under the dash. I did but never used that option. I am considering installed the system in my 1974 come spring. I have two colleagues with them in their C3s and believe me they are very effective.
My thought for the day.
Check DRL-1.
http://webelectricproducts.com/
These are standard NAPA Wagner halogen "H" lamps as well. No need for relays.
Another option is Hella lamps behind the grilles but that gets a little more expensive. My former 1979 is shown.
Old Nov 16, 2008 | 05:53 PM
Go Vette's Avatar
Go Vette
Great idea. Thanks for the info!
Old Nov 16, 2008 | 06:29 PM
Mad Vette's Avatar
Mad Vette
When GM first introduced daytime running lights on their new cars I remember them advertising a kit to retro fit older cars like First gen Cameo's, GTO's and Corvette's. I wounder if the kit is still available.
Old Nov 16, 2008 | 07:04 PM
Paul L's Avatar
Paul L
The kit noted above will suffice.
Old Nov 17, 2008 | 11:18 AM
danno12345's Avatar
danno12345
This is perfect timing. I have been pondering the last few days about how to do this, but I was thinking of using the parking light filament, using a diode & a relay to isolate it from the back & turn on with the key. This might be easier.
I just added a third brake light, so this is a logical next step.
http://forums.corvetteforum.com/c3-t...ht-for-c3.html
Thanks for the link!!
Dan
Old Nov 17, 2008 | 12:02 PM
1nicecorvette's Avatar
1nicecorvette
webelectricproducts is a great company too. L.T. stands being his work ive dealt with him several times for my mustang sequential tailights. great solid products!
Old Nov 17, 2008 | 01:52 PM
Young69Owner's Avatar
Young69Owner
Anyone know where I could connect the brown wire coming out of the back of the front turn signals so that my amber lights did this (DLT)? I've been pondering this and I just wired my sidemarkers to blink. Let me know if you want to do this. It is very quick, but you may need a solid state flasher module, but I can tell you where to get it. It will also allow you to use LEDs on all your lights. My Cibie headlights are supposed to have a parking light setting, so once I install them, you will see them on when I have my parking lights on (through the grill!) I also thought about putting red brake lights in with my reverse lights, but thought wiring them to turn off with the reverse lights would be too complex. Anyways, not trying to hijack, just having fun with wires...
Old Nov 17, 2008 | 02:29 PM
7T1vette's Avatar
7T1vette
I leave mine in the garage during inclement weather....
Old Nov 17, 2008 | 05:48 PM
Bee Jay's Avatar
Bee Jay
I wired my front parking lamps to come on anytime the car is running. I used a relay. Very simple to do.
Bee Jay
Old Nov 17, 2008 | 07:41 PM
Paul L's Avatar
Paul L
Bee Jay
The trick is to have the bright filaments on the 1157 bulbs on. That is what the module does. Just parking lamps does not do it.
Old Nov 18, 2008 | 11:56 AM
Young69Owner
I ordered a DRL module from Daniel Stern. I am making sure that they will be safe with my Luxeon LEDs. Apparently, the do get hot, but they dim slightly if left on bright for a long time. I was told that I will barely notice.
Old Nov 20, 2008 | 10:22 AM
Young69Owner
Everything is safe and ready to go. The DRL is an easy install and uses quick splices. I just had one question. What is a good wire to use that gets juice when the car is turned on? They recommend that it is fused for 15A. Windshield wipers? Any ideas? Is there one near the blinkers?
Old Nov 20, 2008 | 10:28 AM
1nicecorvette
check this out here. some useflul information on the DTRL's and other things you never knew how to fix! http://www.iotech.no/corvette/projec...driving-lights
Old Nov 21, 2008 | 12:48 PM
Young69Owner
That's cool, but my '69 doesn't have an alternator warning light. I know that the alternator always has power, so I can't hook it up there either.
Old Dec 3, 2008 | 05:49 PM
lakebumm's Avatar
lakebumm
2022 C2 of the Year Finalist - Modified
Ttt
Old May 21, 2025 | 10:05 AM
Heirloom75Coupe's Avatar
Heirloom75Coupe
Commenting & reviving this old post because it's still relevant for C3 DRLs. I was searching for a DIY circuit forever and stumbled across this (THANK YOU, Duck Duck Go search engine!).
The DRL-1 mentioned in the first post is this link, and still appears to be available.
https://www.webelectricproducts.com/...hts-p264368736
Old May 21, 2025 | 01:29 PM
vettebuyer6369's Avatar
vettebuyer6369
17 years later, time to start a new thread for people to head it.
To Daytime Running Lights (DRLs)
