Terminal Size
Old Nov 17, 2008 | 08:05 PM
Oldguard 7's Avatar
Oldguard 7
Default Terminal Size
What size spade (male) and female terminals I need run wire from my electric choke to the fuse panel. The wire is 14 gauge. I need the type of terminals that do not have plastic around the metal so I can see where and how I'm crimping the terminals. Thanx in advance.
Old Nov 18, 2008 | 06:18 AM
RunningMan373's Avatar
RunningMan373
14 will take a Blue.
Old Nov 18, 2008 | 08:26 AM
Durango_Boy's Avatar
Durango_Boy
Originally Posted by Oldguard 7
What size spade (male) and female terminals I need run wire from my electric choke to the fuse panel. The wire is 14 gauge. I need the type of terminals that do not have plastic around the metal so I can see what how I'm crimping the terminals. Thanx in advance.
Yep, a blue sleeved terminal will fit that gauge wire. I usually remove the plastic sleeves as well. It makes for better crimping and heat shrink tubing is much easier to slide over.
Old Nov 18, 2008 | 03:45 PM
Oldguard 7's Avatar
Oldguard 7
Blue sleeve terminal? I'm assuming these are the terminals have a plastic blue sleeve that can be removed? Where can I find them? Advance, Auto Zone, etc?
Old Nov 18, 2008 | 03:49 PM
Durango_Boy
Yeah, the color indicates the size. Red is the smaller terminal, used with 20, 18, and 16 gauge. Blue is medium, for 16 and 14, and yellow, for 12 and 10.
Sometimes the sleeves are hard to get off. I use various hand tools to aid in their removal.
To Terminal Size
