Headlights won't turn on
Old Nov 21, 2008 | 11:53 PM
raulotero91's Avatar
raulotero91
Default Headlights won't turn on
Hey guys I have a problem with my vette. I removed the headlight switch **** to install a new dash cap and when i tried to put it on, I put the **** in and sparks flew. After that, i tried to see if it had messed up the lights and it did. none of the lights would come on. I know someone is going to tell me that i should switch the lights but i know for a fact that switching them won't help. Does anyone know if their is a fuse or circuit braker to fix the problem or do i have to buy a brand new h/l switch?
any feedback would be appreciated.
Old Nov 22, 2008 | 12:43 AM
ripforrey's Avatar
ripforrey
should be a fused circuit. check that 1st.
Old Nov 22, 2008 | 01:02 AM
TimAT's Avatar
TimAT
It is a fused circuit. But not a typicl fuse. It's fusible link, find that and you'll find it's cooked. replace it with a new link and it should work.
Old Nov 22, 2008 | 10:08 AM
Durango_Boy's Avatar
Durango_Boy
I'm puzzled as to why inserting the headlight **** shaft would result in a sort. Faulty switch?
Old Nov 22, 2008 | 11:26 AM
raulotero91
How do i find that? what does it look like?
Old Nov 22, 2008 | 11:47 AM
pacrimmat's Avatar
pacrimmat
I am guessing that he forgot the cardinal rule.
" ALWAYS DISCONNECT THE BATTERY BEFORE PROCEEDING".
Old Nov 22, 2008 | 12:29 PM
7T1vette's Avatar
7T1vette
The switch has internal contacts. You shorted them out when you inserted the [metal] shaft into the switch {without disconnecting the battery}. It could have been worse.
To Headlights won't turn on
