I need some advice please. Test drove '73 with what I believe is crate motor with lots of add ons;ie Edelbrock Intake with Holley ,valve covers , Hooker headers, elestronic ignition many other goodies. The problem is on start up engine is quiet and strong sounding good response from throttle. however when operating temp. is achieved there is a knock on the fuel pump side. The car seems to perform without any other issues. Any ideas ?
The quickest way is to warm the engine,shut it off,remove the 2 bolts holding the pump,pull the pump out a little until the rod falls down,drop the pump down and let it lay there,start the engine back up and see if the knock is gone.(engine will run with the remaining fuel in the carb.)
I should say the dealer that has the car has had his shop trying to find the problem. I have purchased the car with the condition that they fix the knock.
So is the car in your possession or do they have it?
We actually changed the fuel pump and rod the noise is still there. Thanks. Could it be in the timing chain?
Originally Posted by DWncchs
When you changed the pump did you use the bolt through the front of the block to hold up the rod?
OH thats sheds new light on it.
If someone changed the fuel pump and used the bolt method to hold up the rod they could have "REBENT" the rod.
A local shop had a vette in and was sure the noise was coming from the fuel pump.They took the pump off and it was broke so they replaced it.Engine still had the noise.They pulled it apart and found the rod was bent so they replaced the rod.Engine still had the noise.They pulled it apart and found the rod bent again and replaced the rod and fuel pump thinking the other pump bent the rod.Guess what -engine still had the noise.I was called and I went over and ask I ask the mechanic to explain his procedure. He was running the bolt in the front of the block to hold up the rod-but because the threads were full of crud he wasnt using his fingers so he could feel the bolt just touch the rod he was using a wrench to get the bolt to go in and bending the rod each time.
The original problem was a broken pump,the mechanic created the bent rod problem.
Op.Tech3- Not saying this the problem with your car but it does happen.
Thanks very much for your input, this is my first purchase of a Vette and so far it's not been a good experience. Other than this issue the car is very clean and straight,but to me this knock is a big deal breaker.
Personally, I think you are hearing a rod knocking...the oil is cold and thick when it starts up, so the knock is dampened. When the oil warms, and thins out, the rod bearing has lots of clearance and is knocking away. Maybe this sounds pesimistic, but as a 'buyer' you have to think the worst....otherwise, you end up with a lemon. Tell them that if they are able to FIX the knock [not just mask it or subdue it], you'll seriously consider the purchase. They might just drop the pan and find/fix the problem. But, as long as you are just 'dangling on the hook', they won't do anything else.
even if they drop the pan and install some bearings this is going to be trouble down the road, you may be better off looking for another deal unless this one is a near give away.
ull the plug wires,one at a time.If the knock goes away,you have found the cylinder and the rod.Many times,as things get warm and expand,those clearances will open up,causing a knock.If it is a double knock,its the piston pin.Replacing a rod bearing(s) is no big deal.Use plasti gauge in case you need a bearing 001 overized.
pull the plug wires,one at a time.If the knock goes away,you have found the cylinder and the rod.Many times,as things get warm and expand,those clearances will open up,causing a knock.If it is a double knock,its the piston pin.Replacing a rod bearing(s) is no big deal.Use plasti gauge in case you need a bearing 001 overized.
Got some more info,the car can sit in the garage and run at idle and never start to knock but take it out for a drive and the knock will start. Any ideas why this happens? Help.
That doesn't change anything. A rod knock can exhibit the same symptom if it's not too bad yet.
If they have any kind of decent shop or have an on-call mechanic have them use an auto stethoscope which will help locate the knocking. A long wooden dowel will do the same thing. If the oil pan is making all the noise or that bottom rail of the block then it's a rod. If it's just the fuel pump it's probably a bent rod. Listen to all the accessories trying to find the source of the knocking.
They actually put an electric fuel pump on it and got the same knock.
Gonna meet with them Monday and go through the accessories.Could it be in the timing chain?I even heard a crack in the flyweel or possibly oil pump.The oil pressure stays at 35 until warm-up then drops to about 25 and flucuates with acceleration back up to 35. Just more thoughts.
You can talk yourself into believing that there is something 'simple' that is causing the knock... But, if that were the case, the dealer would have already fixed it. He hasn't, so there is something significant that is wrong with the engine. Now, if you intend on pulling the engine/tranny and going through them anyway, you have the option of 'playing dumb' and low-balling the dealer on his/her price. If that's not what you are planning to do, take a walk from this car. [just my 2-cents]
