Royal Purple Bad?
Afer reading this I have been using royal purple ever since.
Dave
Group III's impact on seals isn't any different from conventional oils due to the similarity of the basestock. Group IV PAO basestock causes seals to shrink. Group V polyol ester basestock cause seals to swell. In the early days of synthetics, most were PAO basestock. This basestock caused seals to shrink and lead to leakage. This was compounded as synthetics have better natural cleansing properties along with a generally higher level of detergents. Both combined to clean out sludge that had built up exposing old dried out seals to fresh oil, oil that caused the seals to shrink, thus leakage.
This was a long time ago. In the interim, the oil companies learned that by adding a small amount of polyol ester to a predominantly PAO basestock fluid, the fluid's coefficient of friction dropped significantly, and the resulting fluid caused porous materials to swell sightly vice shrink. Thus, in general, a high quality modern synthetic shouldn't cause a seal to leak unless it has mechanical damage that was masked by sludge built up over time.
As for the quality of RP, I clearly chose to use, and later market, AMSOIL. While AMSOIL hasn't included RP in all of its comparative testing yet, they have in some:
AMSOIL Motorcycle Oil “White Paper” (1 MB pdf file)
AMSOIL Gear Lube "White Paper" (2 MB pdf file)
And there is some wear tests on these AMSOIL product data pages:
AMSOIL Dominator Racing 10w30
AMSOIL Dominator Racing 15w50
Many will say that the 4-ball wear test isn't appropriate for an automotive motoroil, but based on my own personal review of hundreds of used oil analysis reports on the oil forums, there seems to be a pretty good correlation between a low 4-ball wear result and low wear results in actual service. For me, that carried weight, but to each his own.
C66 Racing #66 NASA ST2, SCCA T2
AMSOIL Dealer (Forum Vendor)
AMSOIL Preferred Customer Program (Members buy at Wholesale - a savings of about 25%)
and have every since it has been out. Hot Rod performed the dyno test against other synthetics and it made 5 to 7 more hp than all others.
I use it in every piston engine I own and trans/rearend. Its the best!
Quite frankly I can tell a difference in power vs amsoil when I drained one and replaced it with another in my ZR1.
) change oil every 3-5,000 miles. Mobil 1 on C5, whatever works for you is my motto
Although I am a scientist, I'm not an expert in tribology (the study of friction and lubrication). However, I have worked with solid lubricant additives in greases (moly disulfide, polycarbon monofluoride, etc...) and understand friction testing. Good data from an independent test lab is tough to come by, because somebody has to fund the study. If the product from the funding organization dosen't come out on top, then it dosen't get published.
I have a couple of ongoing tests parked in my driveway that have told me what I need to know.
Amazing how the vast majority lived very long and healthy lives without the need for ultra super zoomy oils.
Anybody in the engine overhaul business will tell you that those engines that went full term did not need a shop visit for lubrication related reasons. They'll also tell you that an engine that is failing cannot be 'saved' by ultra super zoomy oils.
But I'm wasting my time stating this.
i dont believe in hearsay. i believe in cold hard facts so all this discussion is pure speculation until someone posts up some oil analysis. showing wear of one oil and then wear with another oil in an actual engine by an actual consumer. all other stuff is merely advertisement wrapped in a scientific looking wrapper. oil is kinda like religion. once someones mind is made up, every one else is an idiot.
Lifter failures, ring failures, and cruded up engines can all be a result of oils not doing there job. The internals of an engine can get pretty cruded up from the impurities of conventional oils.
Carbon build up is a major cause of engine failures.
I was told (or heard) that synthetic oil was sooo slipery that when used on a vehicle that sat for a month or longer without being started, the oil would literally slid off the cam as well as other parts). This creates an ugly environment for starting the engine...dry for a few seconds.
Any thuth to this?
BTW I do use synthetic in my daily driver and Diesil in my Vett (for the lifters)
