Seriously Considering Webers for Future.
Old Nov 22, 2008 | 10:44 PM
Durango_Boy's Avatar
Durango_Boy
Originally Posted by billla
High cool factor, but I have to think they'd be a PITA for a daily driver.
I have to agree, and while I CAN drive this car daily, I usually don't. I think it might be worth it just to pop the hood and see those carbs sparkling. It's a very attractive setup.
Old Nov 23, 2008 | 12:15 AM
vettesbydesign's Avatar
vettesbydesign
DB.....I don't have pictures on the computer(was before I had one),but had a tricked out 85 T-top Camaro w/a built 355.No webers,but had a small 144 blower w/dual mounted Holley 4 barrels on each side,and custom air cleaners.It was pretty cool on the WOW factor at car shows,and ran real strong.I wanted to put nitrous on it,but got bored w/it,and someone offered me stupid money,so.....I have photographs left.
I like odd inductions tho'.There are some Hilborn setups on ebay right now.I have had them also,and they are pretty...
My 6 custom HOlleys I run on the green 68 were a bear to sync in,and this isn't a very streetable setup from the late 50s,but ALOT of patience,and tweeking....she idles around 900,and runs very strong,and when you open the hood for someone....ahhhhhh....
Old Nov 23, 2008 | 12:20 AM
vettesbydesign
I'm not trying to highjack here,but do any of ya all know where another forum member can find a Can Am style intake for Webers for a BBC?Dr.L88 has been searching for this setup,or leads on one.
Old Nov 23, 2008 | 12:20 PM
ram82fire's Avatar
ram82fire
I have been running a crossram with 4 dcoe 45's for four years and have never had any tuning or adjustment problems in that period of time on my 82 .
gman
Old Nov 23, 2008 | 05:14 PM
Thmprr's Avatar
Thmprr
35 yrs ago, I ran a 331 with a Moon 4 x 48 Weber IDA set up. It ran nice, but tended to lean out at anything over 7000 rpm. When IR, you need at least 55mm to run a 383 or 406. Weber used to sell 51mm IDA's but not sure now. Essentially, the IDA is the same as the DCOE as to function. I used to get 5 mpg, though, shame as it looked so cool.
Someone out there runs small car EFI throttle bodies on the 4 x IR manifold, horizontal or vertical, got an idea he is on this forum too.
Old Nov 23, 2008 | 05:52 PM
blnvette's Avatar
blnvette
I like my 40 dcoe with 28 mm venturies. Thats enough fuel for my blown 383.
I've had them for 18 years. You can make the cfm almost any size you want, by changing the venturies and chokes, and rejetting. Tuning these is left for the experts.
Old Nov 23, 2008 | 06:00 PM
Guru_4_hire's Avatar
Guru_4_hire
Cruise-In IV Veteran
Cruise-In V Veteran
the Grandsport corvettes had a 377 small block with the cross ram and 58mm weber, for perspective.
Old Nov 23, 2008 | 07:07 PM
Durango_Boy
Well my 405 is a torque monster and won't see north of 4500 very often so I certainly won't be worried about my mixture at 7K.
What's IR in your explanation and are you saying that the two 45mm DCOE carbs won't feed my 405?
Old Nov 23, 2008 | 07:54 PM
Durango_Boy
I found an Australian Holden FX / FJ with a SBC and a setup like the one I am contemplating. Mine would be more modern carbs, probably higher flow, different fuel line setup, and my 405 will look a lot different than that small block. However, the look will be about the same and I think it would look very sharp.
Old Nov 23, 2008 | 08:58 PM
gkull's Avatar
gkull
4 psi max and 3 min
Old Nov 23, 2008 | 10:51 PM
Durango_Boy
Originally Posted by gkull
4 psi max and 3 min
Okay good because I have an electric feeding my current carb and I'll be able to r-use it. Perfect.
Old Nov 24, 2008 | 08:00 AM
lvrpool32's Avatar
lvrpool32
I'm running 4 x 48 DRLA del'lortos, took a little work to get them first set up and jetted right, they are very sensitive to fuel pressure..but they run/sound great.
Old Nov 24, 2008 | 05:44 PM
  #33
Thmprr's Avatar
Thmprr
I was explaining or trying to, the difference between your set up with the 2 x 45mm dcoe's feeding a manifold vs the IR (individual runner) set up that you get with the 4 x webers. Amazing that Chevrolet had it right on back during the 60's Grandsport days with the 4 x 58mm IR.
2 x 45mm DCOE feeding any 4bbl manifold should be fine, as others have said, they are almost infinately tunable using venturies, mid range emulsion tubes and jetting both mixture and air bleeds. The only downside is, cost of the tuning parts, that's why it's best to get a shop to do it that's always doing it, because tuning needs to try things, and it gets expensive if you haven't already got them.
Old Nov 24, 2008 | 06:03 PM
  #34
Durango_Boy
I think I have a shop here in town that can tune these. The other aspect is that Inglese as a company claims that they can pre-tune these setups for my engine based on my specs. They set it all up and ship it so that it bolts on and I can start up. I understand that without the car they cannot get it perfect, which is why I would make sure it spent some time with my local guy who has a portable 5-gas machine to tune it to perfection.
