Surface Rust Removal Questions
Old Nov 23, 2008 | 03:50 PM
Inshakoor's Avatar
Inshakoor
Default Surface Rust Removal Questions
I'm looking to get rid of the surface rust on the frame and pretty much anything else I can reach in the car. I bought a small wire brush and a wire wheel that you can attach to drill. The wire wheel is coarse, but they offered a fine one as well. Do I need both, one or the other? Now, A) Is that the right way to go about removing the rust, and B) Since I'll need to coat whatever I remove rust from pretty quickly, what do I coat it with? A Rustoleum product and then a coat of high heat spray paint? I really don't know and would appreciate people's experience with it. Thanks a lot!
Examples Of Rust Locations
Old Nov 23, 2008 | 04:14 PM
Durango_Boy's Avatar
Durango_Boy
Wire brush, wire wheel, Scotch bright pads, sanding discs...anything like that. It'll cut down very fast and you'll have bare metal that you'll want to paint and coat quickly.
Maybe invest in some Por-15 as that's a way to take metal sealing very seriously.
Old Nov 23, 2008 | 05:38 PM
7T1vette's Avatar
7T1vette
With a product like POR-15, you want to have some rust on the surface...not just bare metal. So, a coarse wheel, etc. should be good if it gets all the loose stuff off.
Old Nov 23, 2008 | 05:44 PM
72LS1Vette's Avatar
72LS1Vette
Check out www.rustbullet.com
Very little prep needed. Sticks well to either rusted or bare metal.
Rick B.
Old Nov 23, 2008 | 06:16 PM
...Roger...'s Avatar
...Roger...
Anybody use Ospho ?
Old Nov 23, 2008 | 07:18 PM
noonie's Avatar
noonie
Originally Posted by DWncchs
Anybody use Ospho ?
Yes I do
I pressure clean and degrease first with a 3500 psi short wand,
Then use a small weed sprayer with Metal Prep from Homey Depot (same as OSPH but a lot cheaper 13 bucks/gal, Phosphoric acid)
Angle grinder with cup wheel if needed.
Do all the metal underneath and inside the frame too and then just rinse off and paint with Rustoleum primer and semi black.
If it's not going to see winter salt, that is plenty good enough and the finish looks a lot better than Por15.
Old Nov 23, 2008 | 07:43 PM
Inshakoor's Avatar
Inshakoor
Thanks for all of the suggestions. I'm not sure how I feel about leaving the rust on the metal and then working on it. Obviously that sounds great as it sounds like a lot less work. IF I'd like to take off all of the rust first, is there a better way to do it? If I use the wire wheel, how do I use it without leaving wire lines on the metal? Do I have to sand it down or use a fine brillow pad to get any lines out of the metal? After I get the rust off with a wire wheel/brillow pad, do I still coat it with Por-15 or Rustbullet? Do I need to "paint" over the POR-15 or rustbullet after I use it or will the finish be good enough? Noonie, is that just the Ospho that's on your frame? Did you paint everything with it? It looks pretty dang good to me. Thanks again for all of the help, I just want to make sure I do this right as I don't want to do it again unless I do a Frame-Off (yeah right).
Old Nov 24, 2008 | 12:13 AM
noonie's Avatar
noonie
Use a good quality wire cup from a welding supply. They don't leave marks and your not prepping a Ferrari hood.
A 3500psi pressure cleaner or higher will cut right thru the fiberglass, so it will knock off most of the rust pieces.
The phosphoric acid will clean the rust to bare metal if washed off while wet.
If left to dry it will convert to stop the rust from getting worse.
The picture of the unpainted caliper and rotor is after the ospho had been washed of before it was dry. They were previously pretty rusty.
The black paint is just Rustoleum paint over primer and ospho prepped metal.
Old Nov 24, 2008 | 10:59 AM
72LS1Vette's Avatar
72LS1Vette
Rustbullet automotive is silver so you can either leave it as is or topcoat it with any kind of paint. I used Rustoleum Satin Black with a lot of thinner for a top coat.
Rick B.
Old Nov 24, 2008 | 11:12 AM
rosslato's Avatar
rosslato
i wirewheeled my frame and sanded where i had to then did the por-15 thing and topcoated. you can pickup the phosphoric acid at home depot, it's called "a must for rust". pics here http://forums.corvetteforum.com/c3-g...cs-inside.html
more pics here http://smg.photobucket.com/albums/v323/rosslato/
Old Nov 24, 2008 | 12:55 PM
Inshakoor's Avatar
Inshakoor
Rosslato, wow...Incredible job. The car looks amazing! Words don't even describe it's glory So you wire wheeled the frame (coarse or fine, or both in succession?) then did the por-15 thing (you used "a must for rust" from Home Depot?) and then put on a top coat? Okay, that makes sense. The "a must for rust" goes on AFTER using the wire wheel, right? It coats the bare metal to be rust "proof" so to speak, right? Thanks for the info Rosslato, that helps alot.
Quick opinion question: My 'Vette is silver and I want to keep it looking stock as much as possible. Original parts aren't going to always be possible, so new or rebuilt will work, i just want it to LOOK stock. With that said, what color do I paint the frame? What did they look like new? Silver, Black? Thanks for the help!
Old Nov 25, 2008 | 11:25 AM
rosslato's Avatar
rosslato
thanx for the comment. the frames came black but not sure which black, i prefer semi black. i'll send u a PM.
Old Nov 26, 2008 | 05:36 AM
hunt4cleanair's Avatar
hunt4cleanair
Looks like "light" rust compared to what I'm working on. I've used Rust Cure and Rust Encapsulator (by Eastwood) and both work similiarly...they convert rust. Seem to work better that you scrap or wire brush heavy rust as suggested by others. The Rustoleum Satin Black seems to be a pretty good match for the frame finish.
Old Nov 26, 2008 | 06:34 AM
SH-60B's Avatar
SH-60B
Originally Posted by noonie
Yes I do
My car will never see winter salt either, but sand or road debris will be kicked up onto it, so I did use POR15 for it's chip resistance. It's really not any different to apply, but it is much more expensive than Rustoleum.
Old Nov 27, 2008 | 02:50 AM
Rockn-Roll's Avatar
Rockn-Roll
I don't use the "coarse" wire wheel...it's too stiff to get the bristles where they need to be. Use the Fine wire wheels...get like 3 each of the small and large, brush and wheel styles. Also, the individual wires will fall out, so make sure you clean up good or else you will track the wires through the house and will be getting stuck with them...just one of them sticking into your heel will have you limping for a week...very painful.
I used Rustoleum rusty metal primer followed by Black Night Metallic...looks great, but chips easily. I've got an air compressor on order, and when it gets in I'll be getting a spray gun and painting it with Stratoclear ...that will take care of the chipping. I tried the rustoleum clear coat and it sucks...even tried verathane polyurethane and another brand of urethane without much success. It seems the only way to get a nice hard finish is with an epoxy style clear coat.
Old Nov 27, 2008 | 04:49 AM
Inshakoor's Avatar
Inshakoor
Many thanks to the excellent comments and ideas. I can't wait to get rid of the rust, but engine tune and maintenance will have to come first. None the less, I'm getting ready to order the goods so I'll have it when I want it. Happy Thanksgiving!
Old Nov 27, 2008 | 12:11 PM
AllC34Me's Avatar
AllC34Me
Senior Member
St. Jude Donor '10
Great responses, I was all ears for this one. Make sure you take pictures and share them back. Happy Thanksgiving.
David
77Sleeper
To Surface Rust Removal Questions
