Check the wiper motor ground. I had the same problem on my 77 and found the ground bad. On mine the ground is a seperate single black wire connection on the motor.
that is an indication the motor is not physically at its park position.
the motor has to be at the park position to operate, it will click and nothing else.
also you will need to verifiy the vacuum relay interlock is working properly.
69VETT
