2 Gauges
Old Nov 29, 2008 | 01:33 PM
gunny53's Avatar
gunny53
Cruising
Default 2 Gauges
Guys and Gals I have a 1980,The clock doesn't work which is normal does anyone knows who rebuilds them, also the low fuel unit will not light up bulb,have changed bulb and I'm getting power there does anyone rebuild these?
Thx
Gunny
Old Nov 29, 2008 | 01:57 PM
Eddie 70's Avatar
Eddie 70
Ci 6, 8 & 10 Veteran
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15
Just read a thread over in the C3 Tech section that has a few names of folks that do work on gauges. Maybe one of them can help you out on the clock.
http://forums.corvetteforum.com/c3-g...-business.html
Old Nov 29, 2008 | 02:25 PM
gunny53's Avatar
gunny53
Cruising
Default 2 Gauges
Thanks for the help on clock site,also I think the low fuel light just has a bad transistor.
Old Nov 29, 2008 | 11:39 PM
Willcox Corvette's Avatar
0Willcox Corvette
Former Vendor
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15
You can purchase the clock movement kit, it's cheap and anyone can install it. http://willcoxcorvette.com/product_i...oducts_id=2855
The main problem with the electric clocks is the clutch in the clock. The instructions that come with the kit detail how to test and make adjustments with the clock clutch too!
Your clock should be a quartz clock, and it is rare that they fail. I would make sure to pull the dash bezel center and test the power going to the clock before I rebuild it. I would hate to see you tear it out and have another issue.
On the low fuel warning module, I have the schematic here for it if this will help you. http://willcoxcorvette.com/repairand...lp.php?hID=211
I also have them used in stock. You can find them in the "used section" on the web site. http://willcoxcorvette.com/product_i...ducts_id=25751
Have you inspected the printed circuit board yet? Both issues may be related to the printed circuit too!
Willcox
Old Nov 30, 2008 | 08:40 AM
RoadKing96's Avatar
RoadKing96
From: Holly Springs, Nort Cackalacky / Jupiter, Florida
gunny,
I highly recommend Bill at
Harrisonspeedometer.com
Give him a call, you won't be disappointed.
RK
To 2 Gauges
