rallye hub cap removal
Old Nov 30, 2008 | 02:40 PM
yellow94coupe's Avatar
yellow94coupe
Default rallye hub cap removal
What's the best way to remove the center cap on the factory rallye wheels without damaging them?
Old Nov 30, 2008 | 02:58 PM
shmoky's Avatar
shmoky
I use my fingers and just pull.
shmoky
Old Nov 30, 2008 | 03:08 PM
yellow94coupe
Of course the first wheel I tried is darn near impossible which is why I was thinking there's got to be some trick to this. The other three pulled off fairly easy. I managed to get the first one to come off but I had to pull really really hard.
Thanks Shmoky!
Old Nov 30, 2008 | 03:46 PM
Curby's Avatar
Curby
Cruise-In VII Veteran
St. Jude Donor '06
I use a paint can opener from Lowes to take mine off. It seems to work well, and is small enough to get in there without damaging anything.
Old Nov 30, 2008 | 08:55 PM
7T1vette's Avatar
7T1vette
Fingers usually do it. Sometimes, fingers of one hand behind the outer rim (at top, pulling) and palm of other hand on cone pushing down will pop it off. If those won't work, use a 'pry' tool...but make sure it is plastic or wooden and is wide enough to not deform the rim of the cap.
To rallye hub cap removal
