Custom rear window install
Old Dec 5, 2008 | 03:27 PM
ANY VETTE's Avatar
ANY VETTE
Default Custom rear window install
For those of you that have changed your later C3s to a removable rear window using the older window and hardwware(72 -68) could you have used your own window and custom made some pieces giving it the same function... in and out when you want it?
Old Dec 5, 2008 | 04:01 PM
Durango_Boy's Avatar
Durango_Boy
Technically yes, because I looked into doing that, but the glass is very fragile, and without a true frame like the removable windows have, you're risking breaking it every time you touch it. Not to mention that there has to be a lot of pressure holding that window to a seal to keep water out.
I have done two of the conversions and it really is worth the money to be able to just pop the two latches, take the window out, and not worry about breaking anything.
Old Dec 5, 2008 | 04:57 PM
Alan 71's Avatar
Alan 71
Hi AV,
In the last week or so there was a thread started by someone who is in the process of doing what you asked about and what DB described. Perhaps you can search for it and find it interesting.
Regards,
Alan
Old Dec 6, 2008 | 02:26 AM
colin75's Avatar
colin75
I just finished my conversion using factory hardware that bolted right up. Although i had to notch out the panels for the latches there was mold marks on the backside that made it easy. I used my window and fabbed up a frame using 1/4 in aluminum c channel i got from lowes in the screen section. I was able to form the channel around the window after putting notches in to allow it to bend inward. But make the bends right the first time or it will snap. After getting all bends right i used 3m fast setting urethane to set the glass in and toothpics to keep glass centered. After it set up i wirebrushed and painted my frame. Looks great and sure added strength to that flimsy glass.
Old Dec 6, 2008 | 09:48 AM
Durango_Boy
Did you take pics you can post?
Old Dec 6, 2008 | 09:54 AM
NMsharkracer's Avatar
NMsharkracer
From: Formerly from the Great White North but now residing in the Desert Southwest NM (The Land of Dis-Enchantment?)
I junk yarded all the parts and clips. Got a stock frame with broken glass from a '72 and put lexan in it. All the mounting holes were in my '73 and it went together in a couple of hours. That's the good news. When I installed my roll bar it made the window virtually impossible to remove...oh well
Old Dec 8, 2008 | 09:29 AM
ANY VETTE's Avatar
ANY VETTE
Thx for the info Colin , but did you not have to install some kind of pin feature at the base?If not how did you get around this?
Old Dec 8, 2008 | 03:02 PM
colin75's Avatar
colin75
and thank you for reminding me on this. after drilling two holes in the frame before installing glass i used 1 inch long rivets that i pulled out the pins and cut the tops so they would be shaped like a T and they fit into the inside of the frame perfectly. after urethane sets up they are permenant. i cut and shaped solid rubber inserts for the pins to set in. by drilling the holes offset towards the frame it helps seal when locking the top in. the rubber pieces i got from lowes also in the hardwware section. with a drip of baby oil in the drilled holes the pins slip right in and remove easily. i should have taken pics but i will do this next week on my days off and get them posted.
Old Dec 8, 2008 | 03:24 PM
ANY VETTE's Avatar
ANY VETTE
Wow thanks again, I will be looking for ward to pics as I am sure a few others will!
Old Dec 8, 2008 | 03:32 PM
ANY VETTE's Avatar
ANY VETTE
Hey Durango would my 76 window fit into a 72 frame?
Old Dec 8, 2008 | 03:35 PM
Durango_Boy
Your stock '76 glass will not fit the frame of a '68 - '71 frame from the removable rear window. However, the glass can be cut down by a professional shop if you have access to a stock frame and want to use your existing glass. I think the earlier glass might have been thicker though.
Old Dec 15, 2008 | 01:51 PM
ANY VETTE's Avatar
ANY VETTE
Will be looking for your pics Colin.
Thx
To Custom rear window install
