Power steering problems again
Old Dec 7, 2008 | 12:21 PM
ohfiver's Avatar
ohfiver
Default Power steering problems again
Replaced pump 10-12-06, less than 400 miles on it and now hard to steer at low speed. Checked and lines are seeping fluid could this be the problem?
Old Dec 7, 2008 | 01:08 PM
ripforrey's Avatar
ripforrey
Need more info.
FYI, I had a local hydraulic shop rebuild my all my hoses for $6 each.
Old Dec 7, 2008 | 02:21 PM
Jim Shea's Avatar
Jim Shea
A little seepage from your hoses is not going to cause your power assist to stop working - unless you are now very low of fluid in your pump reservoir. If you are very low of fluid your pump should be making lots of noise as it sucks air and oil together.
Otherwise, I would suggest that you have a pump problem as well.
Jim
Old Dec 7, 2008 | 03:33 PM
ohfiver's Avatar
ohfiver
Thanks guys, Jim I was afraid you would say that.
Old Dec 7, 2008 | 03:50 PM
chvet73's Avatar
chvet73
Just a thought, have you checked your tire pressure. Low tires make for hard steering.
Old Dec 7, 2008 | 06:08 PM
GUSTO14's Avatar
GUSTO14
In the early 90's I rebuilt the front suspension on my 1973. Purchased everything from VB&P, including all new hydraulics for the power steering. Everything was terrific and I had no complaints.
Some years later I decided to send my steering box off to Van Steel and have them rebuild it. (They did a terrific job!) After installing it, I discovered what "power steering" was really about on the C3!!! It was almost too much, but the wife loves it...
Good luck... GUSTO
Old Dec 7, 2008 | 09:14 PM
StickShiftCorvette's Avatar
StickShiftCorvette
If the valve is not stuck as evidenced by lost motion at the valve when the engine is off.
If the valve is not stuck the only things that will cause hard steering is the pump not producing pressure or a totally shot power assist cylinder.
Old Dec 7, 2008 | 10:57 PM
...Roger...'s Avatar
...Roger...
I have seen over greased control valves act that way.
Old Dec 8, 2008 | 11:30 AM
ohfiver's Avatar
ohfiver
Default Great tips, thank you!
Thanks guys you all have given me more than a few suggestions, will ck. it out!
Old Dec 8, 2008 | 12:07 PM
...Roger...
Guess I should have said if too much grease is forced in with a pneumatic gun the grease will fill the fluid area of the control valve with heavy chassis grease and the valve will not move easily and therefore will not call for the pressure to be sent to the cylinder.
To Power steering problems again
