c-3 oil pan
Old Dec 8, 2008 | 08:13 AM
STODD's Avatar
STODD
Default c-3 oil pan
Any one running a 7qt low profile oil pan in their c-3?? They say they will fit all older chevy's except some novas & chevells. Building 421 stroker motor.
Thanks.
Old Dec 8, 2008 | 10:00 AM
The Money Pit's Avatar
The Money Pit
Fits like a glove.
Old Dec 8, 2008 | 12:15 PM
noonie's Avatar
noonie
7" Deep
Old Dec 8, 2008 | 12:50 PM
jackson's Avatar
jackson
The orange 7" deep pan shown by noonie usually no problem. Often called a "road race" or "circle track" pan, they usually offer a bit better ground clearance than OE C3 pan. Sometimes exhaust fit crowded with this sort of pan but I'd rather not worry about ripping a panbottom; this sort's my pick. FYI ... because circletrack pan are baffled for left turn only, (& if you run a circletrack pan that looks like this in a street car) you should correct/fab a left side door & run a centered pickup ... both as found inside RRpan. Otherwise, motor may starve during right turn.
Can't say the same about shiney pan shown by TMP. Those often called a "T-sump" or "drag race pan" & often hang down even lower than OE C3 pan. More often than not, their depth about 8 1/4" - 8 3/4" .
Old Dec 8, 2008 | 12:51 PM
KapsSA's Avatar
KapsSA
Active Streak: 90 Days
Fits like a glove.
Mine too. Been on my 79 since 1984...
To c-3 oil pan
