Still Overheating
Old Dec 9, 2008 | 01:30 PM
21boy's Avatar
21boy
Originally Posted by jackson
First, verify temps w/ known t'meter.
Sounds like yours sorely needs a thorough chemical cleaning & flush of entire cooling system. Don't simply flush it, CLEAN it too. That rust collects in flues, jackets & passages; can/will cause eratic cooling. I dunno if still available at local GM dealer parts dept ... was under $10 ... heavy duty cleaner GM p/n 12346500 ... it works! Flush then clean then flush again then replace t'stat & cap.
Many posts here on cleaning cooling system; do a search if the above ain't sufficient.
That was suggested to me a week ago. I was going to wait till spring time to do it because of the outside temp. but I didn't think it would have effected the cooling that much. I learned something there. Thanks for the help guys. Sure it'll be fixed in no time.
Old Dec 9, 2008 | 01:45 PM
jackson's Avatar
jackson
Try and open the block plugs ... hex head pipe thread, one each side of block, midway front-to-back, just above oil pan gasket. They're often seized/rusted tight. Plugs out, poke a coathanger in there until water runs clear ... plugs back in ... then begin the flush-clean process.
Be prepared: when motor sits a long time & coolant/water rusty ... be prepared one or more freeze aka expansion plug will rust through & leak.
-also 21boy- suggest fillout your forum profile to include approximate geographic location ... we don't need to know your street address ... but sometime you may need location-specific info.
