Still Overheating
Old Dec 7, 2008 | 02:24 PM
21boy's Avatar
21boy
Default Still Overheating
My 74' overheated after about 10 mins but it was sitting for awhile so I thought it was normal. So I changed the thermostat. Nothing. Changed the water pump. Nothing. I check coolant level daily and there seems to be no leaks. What else can be left? I turned on the AC and the temp rose about 100 degrees in less then 2 mins so I'm assuming somethings wrong still.. Could the thermometer be broken or is there something else that can be replaced? Thanks.
Old Dec 7, 2008 | 03:12 PM
wnmech's Avatar
wnmech
Assuming you werent expirencing any overheating problems before I would check lower radiator hose for collapsing. There is a spring inside the hose that could be rusted away. Check fan clutch. Possibly still air in the system. Posibly radiator finally got restricted flow .
Old Dec 7, 2008 | 03:22 PM
baxsom's Avatar
baxsom
when the car is hot touch the upper radiator hose. if there is a blockage somewhere it wont be as hot as it should be because the water wont be circulating.
you should be able to see the lower hose close up if the spring is bad.
moosie982's Avatar
moosie982
Was anything apart in the cooling system, if so maybe some kind of critter made itself a nest, its happened before, Good Luck,,,
Peace, Moosie
Old Dec 7, 2008 | 03:27 PM
rcread's Avatar
rcread
Is the timing spot on?
Old Dec 7, 2008 | 03:55 PM
capevettes's Avatar
capevettes
CF Community Team
Active Streak: 90 Days
2016 C2 of Year
2015 C3 of Year Finalist
Are you sure you're overheating? Confirm the gauge is accurate by using an IR gun.
Also, overheating at idle is usually an indication that your clutch fan is faulty.
You may also have a radiator problem.
Old Dec 7, 2008 | 07:48 PM
21boy's Avatar
21boy
Wasn't open long enough for anything living to get in there. I'll try the tests though and see what happens. Thanks
Old Dec 7, 2008 | 11:13 PM
Steve COSD's Avatar
Steve COSD
Check the upper and lower radiator hoses. These hoses will become weak or if the spring inside has collasped the hose will also collaspse. This will reduce or even stop the flow of coolant. Did you do anything to the system before it started to overheat?
Old Dec 8, 2008 | 01:26 PM
21boy's Avatar
21boy
The car has sat for 18 years but never over heated before. Haven't had a chance to check if the hoses collapse yet, but was rust in the coolant when I drained the coolant so theres a good chance the spring has rusted out.
Old Dec 8, 2008 | 01:45 PM
Ironcross's Avatar
Ironcross
I know its almost impossible to touch the radiator but you might check for cool spots....Meaning the radiators efficiency had deteriorated and may be plugged. If its warm all over its probably OK
Old Dec 8, 2008 | 02:05 PM
cgc's Avatar
cgc
I had this same problem with my 68. Couldn't idle no time at all and it would overheat. Looking at the cooling fan while idleing it was turning. Long story short I went to junk yard and got different cooling fan and spacer to take up lost space when I removed the clutch. I put fender covers on before changing out clutch and fan. When I started the car the fender covers blew Off. No more heating problens..
charlie
Old Dec 8, 2008 | 03:29 PM
bashcraft's Avatar
bashcraft
charlie
While this is certainly one solution, I would suggest replacing the fan clutch rather than eliminating it.
Old Dec 8, 2008 | 05:22 PM
DAN70's Avatar
DAN70
C1 of Year Finalist (performance mods) 2019
2017 C1 of Year Finalist
Hi, I'm new to this site. I do have a suggestion. When I change thermostats I drill a 1/16 or 1/8 hole in the thermostat. It keeps that air bubble from forming under the thermostat which in turn will not allow it to reach the temp for it to open. Its a cheap simple fix, might work for you.
Old Dec 8, 2008 | 05:42 PM
cargo247's Avatar
cargo247
Old Dec 8, 2008 | 08:23 PM
MotorHead's Avatar
MotorHead
From: Who says "Nothing is impossible" ? I've been doing nothing for years.
YOu might have an air pocket somewhere in the motor preventing proper circulation. I always fill my motor thru the thermostat housing
Old Dec 8, 2008 | 11:35 PM
cgc's Avatar
cgc
Why? I'm still learning.
charlie
Old Dec 9, 2008 | 02:30 AM
73StreetRace's Avatar
73StreetRace
Long ago, I used to have the same kind of problems with my vette.
After changing many parts, including water pump, thermostat, fan clutch, temp sender,... and reverse flushing the engine block / cylinder heads and radiator core, check timing, richness and so on, I still had the same problems ( overheating in Summer when idling ) even if it was slightly better after all this work...
I finally decided to buy a new radiator ( copper core, OEM replacement, even if I regret today not to have bought an aluminum unit ! ).
Since this day ( it was 10 years ago ! ) : No problem any more, and the water temperature is now always between 180° and 200°F, never more, even in the most extreme climatic conditions ( up to 100°F outside ).
It was worth the money
To Still Overheating
Old Dec 9, 2008 | 07:11 AM
bashcraft's Avatar
bashcraft
charlie
Several reasons.
1. The clutch disengages the fan when it's not needed which relates to less noise and less wasted energy.
2. Clutchless fans are usually 4 blade where the clutch fans are 6 or 7 blade so there is more airflow when it's really needed.
3. I have witnessed 2 clutchless fans explode. Both times the radiator was destroyed and one time a blade came through the hood. Clutch fans inherently limit the rpm of the fan to a reasonable level.
4. I have a clutch fan on my 502 and it never goes above 180* even with a '69 small block radiator.
5. GM would not have spent the money and time to use clutch fans if they weren't an improvement over the clutchless fans.
Old Dec 9, 2008 | 10:10 AM
cgc's Avatar
cgc
Several reasons.
Thank you. You made 5 very good points to keep the fan clutch. Like I said I'm still learning. I have the motor out and will start looking into getting a fan clutch.
charlie
Old Dec 9, 2008 | 10:38 AM
jackson's Avatar
jackson
First, verify temps w/ known t'meter.
Sounds like yours sorely needs a thorough chemical cleaning & flush of entire cooling system. Don't simply flush it, CLEAN it too. That rust collects in flues, jackets & passages; can/will cause eratic cooling. I dunno if still available at local GM dealer parts dept ... was under $10 ... heavy duty cleaner GM p/n 12346500 ... it works! Flush then clean then flush again then replace t'stat & cap.
Many posts here on cleaning cooling system; do a search if the above ain't sufficient.
