Help me find the wiring problem!!!
In order to describe why my wiring issue has come to the forefront of my list of things to do, let me describe my most recent embarrassment. It happened about 1 hour ago. I am a police officer in Austin Texas. I recently got my 1980 engine swap done, and I was excited to show my car off to my co-workers. I drove it up to the sub. No problem. I left the sub. Vroom. I got off work at 6:30 am, and I had court at 8:30 am. I drove to a coffee shop. Then I walked out, turned the key and...splat. Hero to Zero. So here I am standing in my cop uniform flagging down the nearest driver (an old lady who chastised me to take this as a lesson, presumably for handing out tickets to people in emergencies?) to give me a jump. Ugh.
I've had issues with the battery getting sucked dry since I've had the car. I spent months disconnecting the negative battery cable every time I got out of the car. Then I got motivated and traced the leak to the ctsy/clk fuse. So I pulled it. I know, Bubba in my blood.
But what I really want to do is find the leak. Now my wiring is certainly ugly looking, but I've read some posts suggesting that replacing the wiring harness is not necessarily called for.
I am totally lost when it comes to wiring. But I have patience and some time.
*** How do I trace my problem? I get confused when I look at the bazillion wires. I don't really know what I'm looking for. Where do I start? Can somebody give me a beginner's overview on how to trace a wiring problem? I have an ammeter. I'm happy to read books, articles or whatever it takes to figure this out.
Thank you thank you thank you for taking the time to read this. I look forward to any help you can provide.
Darrel
Darrel
Usually that causes more issues when the car has been sitting for a while, usually at least over night.
You are probably having a problem with your alternator not charging.
Unless you see an obvious wiring issue, then get the alternator tested first.
But, we can leave it to the OP to clarify.
Courtesy circuit has a delay timer in it. Check the timer.
Sounds squirrely, but check the visor vanity mirror to make sure the light is not on.
the alternator is brand new. it was part of the turn key zz4 crate motor i put in. it seems like if there is a problem with it that it would be from some sort of crappy wiring job i did instead of the alternator itself. any tips on what order the wires should be in?
dwncchs: before i pulled the fuse, i had a 2.4 Amp drain. after i pulled it i had .05 so i narrowed it down to the ctsy/clk set of wires. everything was fine until earlier today. my battery died again. the battery is less than a year old. it has had some hard flogging from multiple jumps and drains though.
so i have a two part problem you could say. 1. with the fuse in, i'd like to find the drain and i don't know how to do that. what exactly am i looking for. when one of you looks at a big jumble of wires, what makes you say "oh, that wire at that spot is causing the problem" 2. with the fuse out i don't want to have grandmas give me jumps any more.
thanks in advance! y'all are great!
Look for the delay timer. Should be orange, or sometimes black, up over the passengers foot well. Unplug that and recheck you drains with the fuse in place.
Get someone to check that stuff out. I think I read that your battery was a year old. Take it back to where you got it and get them to check it. Most places are glad to exchange it, especially just a year old.
Although I am still thinking "loose or dirty cable" on the 2nd part of the problem, the sudden no-start. Where I am, close to the salt water here in Florida, it does not take much.
