Clicking noise?
Old Dec 10, 2008 | 12:53 AM
Turbotrad's Avatar
Turbotrad
Default Clicking noise?
I bought a 1969 with a 350/350 about two months ago.
Just today I replaced the carburetor's power valve and cleaned the metering block with compressed air. Now the car will idle on it's own, at least for now.
I notice a distinct "clicking" noise coming from the engine when at idle. The noise speeds up as I add gas until it's too rapid to detect any longer, but returns when I let the car return back to idle.
What is this clicking noise?
It's sort of a "tick" sound, and sounds maybe like a pressure release.
I'm relatively new to this obsession of maintaining an older car, so I appreciate all the help I can get.
Old Dec 10, 2008 | 01:30 AM
gingerbreadman1977's Avatar
gingerbreadman1977
most likely sticky lifter. there are additives to help free a stuck lifter but really only replacing them is the surest way to fix it.maybe look for a loose exhaust manifold or bad seals.
Old Dec 10, 2008 | 07:26 AM
bluthundr's Avatar
bluthundr
Could be a small exhaust leak as well
Old Dec 10, 2008 | 07:41 AM
Turbotrad's Avatar
Turbotrad
Thanks for the help. Hopefully I can get my car to the shop soon. I was planning on taking it in anyway to get the fuel tank and lines cleaned of some rust. It sat for a while after the previous owner died and some rust formed in the gas tank. From what I can see with a flashlight looking into the tank it doesn't seem very bad so hopefully the cleaning won't be too involved.
Old Dec 10, 2008 | 09:02 AM
fotyfobravo's Avatar
fotyfobravo
From: Lake Arrowhead - Georgia > 72 Base Coupe & 74 BB Roadster
If you do not find an exhaust manifold leak, check that its not a worn pushrod from the fuel pump. I have had that more than once. Then check the rocker arms.
A year or so back I posted a similar question about a "clicking noise" in my 454. Someone sent me the following link. It didn't help fix the noise but sure as hell made me laugh.
http://www.youtube.com/watch?v=ZaeAny6zgaU
Old Dec 10, 2008 | 09:21 AM
Paul L's Avatar
Paul L
The PCV valve clicks. Put your finger on it and you can feel the internal plunger opening and closing.
Old Dec 10, 2008 | 09:48 AM
Jims66's Avatar
Jims66
My mechanical fuel pump was clicking awhile back (which sounded like it could have been from the motor). Since I was convinced it was coming from the pump I changed the fuel filter which was so old I couldn't remember how long it had been on the car. It was quicker than changing the pump and needed to be done anyway. When I started the car after doing this....., the clicking sound was gone. It's been several months and the sound has not returned.
To Clicking noise?
