tech/gauges
Old Dec 14, 2008 | 11:35 AM
kidmerc's Avatar
kidmerc
7th Gear
Default tech/gauges
I'm back guys.......I replaced both circuit boards, headlight switch, and all the bulbs.....all the lights worked, great job........I put the dash all back together and took it for a ride, NO turn signals, no temp, no amp, no clock (it didn't work), fuel gauge jumps........quetion, before I tear the dash apart, again (not again), could I have put the lead plug back in upside down?? I know I wrote down the number and took pictures, but I had it in and out so many times, could it go back wrong??? HELP this is on a 78 (pace car)
Old Dec 14, 2008 | 11:44 AM
...Roger...'s Avatar
...Roger...
Not unless you forced it in.It only goes in 1 way.
Old Dec 14, 2008 | 06:55 PM
kidmerc's Avatar
kidmerc
7th Gear
No, didn't force it., thought I had everything working, I'm going to try disconnecting heat sending unit to see if gage moves? It must be a ground or something to make everything quit at the same time....even the tach?
To tech/gauges
