Most Reliable Vacuum Source
Old Dec 16, 2008 | 10:37 PM
Oldguard 7's Avatar
Oldguard 7
Default Most Reliable Vacuum Source
Where on my engine is the best reliable source of vacuum when using a vacuum gauge. I usually remove the vacuum hose on the intake manifold fitting that goes to the check valve for the headlights. any better areas?
Old Dec 16, 2008 | 11:31 PM
Red 71's Avatar
Red 71
From: Melbourne, Fla. 6 months- New Middletown, Ohio 6 months
You picked the best one. That would be the most stable vacuum port. With it you do not have any variability cause by butterflys etc.
Old Dec 17, 2008 | 12:34 AM
7T1vette's Avatar
7T1vette
That is the best one...but make sure all other vacuum system lines are pulled off the carb & manifold and that they are plugged off before you check vacuum level. Then adjust timing to see what max vacuum capability of your engine is. Afterwards, re-plumb the dist. vacuum can back in the system and reset timing. You should show about the same vacuum level as before [if the dist. vacuum can doesn't have a leak].
To Most Reliable Vacuum Source
