C3 Minimum Vacuum
Old Dec 19, 2008 | 02:56 PM
R-Dub's Avatar
R-Dub
5th Gear
Default C3 Minimum Vacuum
Hey guys (and gals) another new kid from Missouri. Can anyone tell me what the minimum amount of engine vacuum is that a guy can get away with and still be able to operate the headlight doors and brake booster on a C3. I'm getting ready to select a solid roller cam for my stroker project and I need to figure out just how much duration I can run. If anyone has any personal experience as to what works and what wont I'd appreciate any input I can get.
Old Dec 19, 2008 | 04:28 PM
john roth's Avatar
john roth
No answers, but more questions, can you get a 12 volt vac pump that will take care of it and buy whatever cam you like ?
JR
Old Dec 19, 2008 | 04:38 PM
GeorgeS's Avatar
GeorgeS
Summit has a few vac pumps that are intended to provide 15 inch if vaccume for the brake booster. I don't wee why they won't work for headlights and wipers. $250 and up
Old Dec 19, 2008 | 04:56 PM
Theiskell's Avatar
Theiskell
Welcome to the forum.....With 9 inches youre lights will go up, but very slow. Oh yeah and it will take a while to build vacuum on a start up
Old Dec 19, 2008 | 06:30 PM
fugawi's Avatar
fugawi
i got 8 1/2 inches with my lumpy cam. everything is slow but works. thought about an electric pump to remedy this small problem.
Old Dec 19, 2008 | 06:39 PM
Gordonm's Avatar
Gordonm
I have about 8 to 9 inches of vacum and mine work just fine. I do not have vacuum assisted brakes but the headlights work just fine.
Old Dec 19, 2008 | 08:34 PM
C3 Stroker's Avatar
C3 Stroker
I also have 8-9 inches of vacuum (with a 250+ duration @ .050 solid lifter cam), and my headlights and brakes work fine. Takes a few seconds more at startup, but no problems.
Old Dec 19, 2008 | 09:36 PM
TimAT's Avatar
TimAT
I'm with C3 Stroker- I get 11-12" with 273* @ .050 on my BB. Headlights are a bit slow but they DO work.
Old Dec 19, 2008 | 11:29 PM
R-Dub's Avatar
R-Dub
5th Gear
Thanks for the input guys, I was aware of the electric pumps but I'm trying to save cash due to tight finances and I'm kind of old school so I'd rather try to keep it "all motor". If the rest of you can get by with eight to nine inches I should be able to run all the duration I want. I talked to a guy on the Comp Cams Tech Line who recommended 236/242 @ .050 on a custom grind with 112* centerline instead of the 110* out of the box to help boost vacuum but it doesn't sound like it's going to be an issue. Once again thanks for the help!
Old Dec 19, 2008 | 11:49 PM
TheSkunkWorks's Avatar
TheSkunkWorks
From: Graceland in a Not Correctly Restored Stingray
IMHO the 112* LSA is a good call, as it will also flatten out the torque curve. Do spend the few extra bucks to get the steel core with iron gear.
Old Dec 20, 2008 | 08:18 AM
76 sting's Avatar
76 sting
Maybe I am confused as I am not as technical as some of you folks here. Shouldn't we mention if we have a small block vs a big block? The durration at 250 will be differnt when comparing a sm to a big block correct?
This is a good question R-Dub because now I know I have a problem as I only get 7.5 at idle in drive (Not park) and brakes stink and headlights now do not work after a brand new engine.
Duration @ 0.050": 242° / 248°
Old Dec 20, 2008 | 11:21 AM
TheSkunkWorks
Tho SB's and BB's are different animals, the effect of widening the LSA a couple of degrees will have the same net benefits (generally, the smaller the cid the more significant the effect). Assuming the cam in question is an XSR series, unless CompCams has recently changed the specs the lobe library does not indicate a variation of profiles between SB and BB XSR grinds. Your cam being a step larger than the one R-Dub is considering, I'm not surprised that you have a bit less vacuum than being discussed here and suggest that a supplemental pump or less cam (if you haven't gone too high on the CR) may be in order for your application.
Old Dec 20, 2008 | 12:58 PM
76 sting's Avatar
76 sting
Thanks...I do not want to run a pump (more weight and stuff to go wrong) and I need 10's at the track so am surley not going smaller on the cam, if anything I want to go a little bigger. present CR is 10.3
What concerned me was that folks here have larger cams then I do which is leaving me to believe that something else is wrong with the picture.
Sorry R-Dub did't mean to hijack
Old Dec 20, 2008 | 01:03 PM
Guru_4_hire's Avatar
Guru_4_hire
Cruise-In IV Veteran
Cruise-In V Veteran
Doesn't compcams offer a vacuum canister?
Old Dec 20, 2008 | 01:53 PM
69Vett's Avatar
69Vett
Corvette of the Year Winner 2017
2016 C3 of Year Finalist
less vacuum slower the acc. are to operate, they will work with 5" eventually.
how long you want to wait ? .....I would guess 10" min 12" for satisfactory operation of wipers and lights. I choose a milder cam, because of preferring better vacuum.
good luck....69VETT
Old Dec 20, 2008 | 04:08 PM
BigBlockTank's Avatar
BigBlockTank
I have 10-11" of vacuum on my LS-5, at idle, and my headlights, wiper door, heat, and A/C all work fine. And the headlights come up pretty quick and at the same time!
BBTank
Old Dec 20, 2008 | 04:13 PM
C3 Stroker's Avatar
C3 Stroker
I see in your info you have a 383, correct?......my cam is bigger but it is in a 427 small block. The extra cubes tame the cam down, making it less radical though the duration is more. Also your choice of heads and intake comes into play, as better cfm flow makes a more efficient engine. My LSA is 108, but my idle is not as radical as some 244 dur. cams I've heard on 383 motors.
To C3 Minimum Vacuum
Old Dec 20, 2008 | 05:51 PM
TheSkunkWorks
You are correct, sir. Yet, another option I should have mentioned...
Old Dec 21, 2008 | 12:04 AM
76 sting's Avatar
76 sting
OK thanks...that makes sense. It now appears that I have a new vac issue.
Old Dec 21, 2008 | 10:38 AM
R-Dub's Avatar
R-Dub
5th Gear
76 Sting, I am not at all offended by the hijack. I jumped in here to try to learn something and I have gotten lots of hard numbers to work with.
I would like to ask TheSkunkWorks to expound a little on his reasoning for suggesting the steel core with iron gear. I assume it would eliminate the need for a bronze distributor drive gear. I'd like to know what the other pros or cons might be. It's been over twenty-five years since I've built a high output engine and things have changed a lot. Back then rollers were only for the big money racer guys.
