C3 Minimum Vacuum
Old Dec 21, 2008 | 02:50 PM
TheSkunkWorks's Avatar
TheSkunkWorks
From: Graceland in a Not Correctly Restored Stingray
Originally Posted by R-Dub
...I would like to ask TheSkunkWorks to expound a little on his reasoning for suggesting the steel core with iron gear. I assume it would eliminate the need for a bronze distributor drive gear. I'd like to know what the other pros or cons might be. It's been over twenty-five years since I've built a high output engine and things have changed a lot. Back then rollers were only for the big money racer guys.
Your assumption is correct. Tho they are effective, bronze gears don't last forever, and those new-fangled ones cost more than just going with the iron gear in the first place. Believe me, dizzy gear problems are to be avoided (once cost me winning class in the IHRA World Finals back in the day). Best way to do so is to just eliminate the problem altogether. As for the core, I wouldn't suggest anything but a steel core for a solid roller, strip or street. Call me old school, but I just don't trust those "austempered" ones.
Old Dec 22, 2008 | 08:37 AM
76 sting's Avatar
76 sting
76 Sting, I am not at all offended by the hijack. I jumped in here to try to learn something and I have gotten lots of hard numbers to work with.
It is the cam manufacture that will usually recomend the type of gear to use on you disty and that is dependant on the type of cam gear used on your cam.
Here you go...I thnk this will answer your questions.
http://www.carcraft.com/techarticles...ars/index.html
Old Dec 23, 2008 | 07:41 AM
R-Dub's Avatar
R-Dub
5th Gear
Thanks for the link 76 Sting, I ordered my new bumpstick yesterday.
I'll be sure to do my homework when it gets here.
