How do you guys do it?
Old Dec 22, 2008 | 06:45 AM
imariver's Avatar
imariver
Default How do you guys do it?
I'm trying to torque the bolt that holds the balancer on my 73. Even with the sparkplugs in it crank wants to turn. How do you guys keep the crank from turnning?
Old Dec 22, 2008 | 07:02 AM
TimAT's Avatar
TimAT
Stick a screwdriver thru the flexplate or wedge the flywheel with a pry bar against the bellhousing.
Old Dec 22, 2008 | 07:12 AM
gkull's Avatar
gkull
I have never TQ it with a foot pound measuring device. I have a manual tranny. So I left the car in gear and put a 1/2 inch breaker bar on the grade 8 damper bolt to tighten it once. It snapped the bolt off flush with the crank snout. It took me a couple hours of cussing to EZ-Out the hardened bolt.
I learned to just make it tight with a lock washer and call it good.
When I have assembled motors on stand I have put a big screw driver through a flex plate and hit the damper bolt with a 3/8th air gun turned down to sub 50 #'s. So it could be done the same in a car with an auto tranny.
Old Dec 22, 2008 | 08:22 AM
yellow 72's Avatar
yellow 72
St. Jude Donor '09
Old Dec 22, 2008 | 08:56 AM
mrvette's Avatar
mrvette
I too am convinced them bolts don't need any 5000 ft lbs on them....I just use locktight red and snug it down....
old Pontiacs used to spec something really stupid like 150 ft lbs or such.....another silly number, just ignored...4 taps with the lug hammer.....
Old Dec 22, 2008 | 01:45 PM
69Vett's Avatar
69Vett
Corvette of the Year Winner 2017
2016 C3 of Year Finalist
Vise Grips on the perimiter of the flywheel will hold the crank in place,
to allow torguing on the crank.
Old Dec 22, 2008 | 02:58 PM
Ironcross's Avatar
Ironcross
hammer handle on the ring gear or any wood product wedged between the bell-housing and ring gear if you dont have an appropriate proper tool. {impact}...as yellow 72 suggested......
Old Dec 22, 2008 | 03:15 PM
TERRY CLARK's Avatar
TERRY CLARK
Old Dec 22, 2008 | 03:30 PM
tfi racing's Avatar
tfi racing
A quick shot on the impact will do it,that bolt isn't that critical.I've pulled apart a few SBC's that didn't even have the bolt or the crankshaft tapped for it!
Old Dec 23, 2008 | 12:40 PM
bj1k's Avatar
bj1k
I made a special tool that works if the engine is out and on a stand. It bolts to the block and has teeth that engage the flywheel teeth to keep it from turning. It also works great for installing clutch and pressure plate.
Old Dec 23, 2008 | 01:55 PM
jackson's Avatar
jackson
I use loctite elsewhere but I don't much like loctite on damper bolt ... never used it on chevy d bolt ... not even race chevy. Not saying loctite's wrong ... to each his own.
To How do you guys do it?
