68 resto need help
Old Dec 24, 2008 | 01:46 PM
naladb's Avatar
naladb
2nd Gear
Default 68 resto need help
Oct 67 built car, L71. Did this car use baffel (metal shield mounts under front stablizer bar brackets) ? Raditor support, does it only have hooks with rubber inserts on the bottom to support raditor or are the small block supports there too, just not used ? I know expansion tank was not used on this car but was the bracket still mounted on the fender well, just not used. Any help is welcome, thanks.
Old Dec 25, 2008 | 01:56 PM
WESCH's Avatar
WESCH
Hi
I have a Oct 05, 67 build BB vert as well.
Pictures of what you mean would help me, but here what I recall is on mine.
Radiator lower mounts are hook type with rubber inserts.
No expansion tank brackets on the fender.
I do not understand what you mean with the stabilizer brackets.
I want to point out that what I wrote is what my car has. Does not mean it's necessarily original.
Rgds. Günther
Old Dec 26, 2008 | 07:21 AM
vettesbydesign's Avatar
vettesbydesign
I don't know what you mean by the shields,either.Please post pictures.
The radiator support shouldn't have the SB style mounts at the bottom.Also,the support will have the "X" bracing for all 68 BB radiator supports.I have seen people try to disguise a SB support w/the bracing on some mid-year supports tho.
Old Dec 26, 2008 | 11:23 AM
R1234's Avatar
R1234
I think he is talking about the lower radiator baffle that attaches to the metal fan shroud and the frame extensions. My #04888 small block has the baffle.
Old Dec 26, 2008 | 12:03 PM
Ironcross's Avatar
Ironcross
Originally Posted by WESCH
Hi
Rgds. Günther
Both of these replys are correct for 1968 L-71 BB cars. No need to have any SB parts on a BB car. It could be the other way around however where a BB was transplanted into a SB car and some of the SB brackets was left on the car by someone thinking the brackets were universal and applying to both engines.
PS, the radiator shroud is plastic and not steel for L71`s
Old Dec 26, 2008 | 12:17 PM
AWilson's Avatar
AWilson
I have a 10/4/67 build date on my 68. It is a SB but yes it does have the lower splash shield that fits between the front stabilizer bracket and the frame.
It sure seemed original to the car. You can see it sitting on the floor:
Here is a current picture of things:
Old Dec 26, 2008 | 01:25 PM
Alan 71's Avatar
Alan 71
Hi AW,
Well, that clears up the question of the 'baffles'. I remember we talked about these a few months ago. I didn't know they even existed. It sure has an intricate shape! Thanks for taking the time to post your pictures.
Your frame looks good, what a big difference.
Merry Christmas.
Regards,
Alan
Old Dec 26, 2008 | 03:27 PM
WESCH's Avatar
WESCH
Hi
Ok , this baffle plate is on my car as well.
Hmm, my shroud is steel , attached to the baffle plate with 2 ears and center top radiator area.
I never heard of this distinguishing feature of BB versus SB, I mean this shroud being out of plastic ?
Rgds. Günther
Last edited by WESCH; Dec 26, 2008 at 03:29 PM. Reason: X-bracing of radiator support is also existing with my 68.
Old Dec 26, 2008 | 03:50 PM
Alan 71's Avatar
Alan 71
Hi Gunther,
I believe I've read that very early 68 cars with a 427, had a copper radiator with a metal shroud and thus the baffle.
Regards,
Alan
Old Dec 26, 2008 | 04:12 PM
Ironcross's Avatar
Ironcross
Originally Posted by Alan 71
Hi Gunther,
Regards,
Alan
Some did Al, but the 427`s in 68 and 69 are actually one piece fiberglass and yes the radiator is copper on those engines for better cooling. I just use the word plastic because I often refer to the Vettes as 'plastic' cars. 1970`s with 454`s are metal though. I think certian 1970-74 SB`s with air use the same shroud as 68-69 427`s....
Old Dec 26, 2008 | 05:20 PM
WESCH's Avatar
WESCH
Hi
Strange.
I have the X-bracing in the radiator support for BB Vettes, but have the steel cooling shroud of a SB ?
Very strange.
I also had a 390 HP March build 68 BB with the same steel shroud.
I am very curios to hear what other 68 BB owners have there.
Rgds. Günther
Old Dec 26, 2008 | 10:53 PM
AWilson's Avatar
AWilson
I'm almost positive that my 68 steel SB shroud has the cross bracing. I also have the original aluminum radiator.
Old Dec 27, 2008 | 09:23 PM
naladb's Avatar
naladb
2nd Gear
First thanks for all the information every one has given over the past few days. I think some information from me may help. This is my first C3 NCRS restoration. I have done 3 top flight C2's,two being 63's, so I know how challanging first year body styles can be. This particular car has all matching number frame and drive train and is a L71 with F41. The bad part was the body was highly customized, so I found a 68 doner body. I know the fan shroud is fiber glass and the radiator is copper, they were present on orginal car.The radiator support does not look correct. The doner car had the baffle but it is a SB and the baffle does appear in the assembly manual. Did the BB have the baffle. I will post some pictures soon to help with the answers.
To 68 resto need help
