In working to eliminate my radio noise I have found a capacitor connected to the positive side of the ignition coil and it is attached to the coil bracket. The AIM, NCRS judging books and other Corvette books I have do not show or mention this capacitor. Does anyones' early 70's have this capacitor? There is a capacity inside the distributor connected to the points and a capacitor on the HVAC blower motor.
I found it in the 73 AIM. It is in section B01-B12 sheet 32. The sheet is labeled Capacitors. Other capacitors are shown on sheet 31. The p/n listed is 1852715.
How do you check a capacitor to see if it working?
Ok, let's say you actually want to replace the cap, for whatever reason. You go to the local auto parts store, the guy gives you a "one fits all" How do you actually know if it's the right one? We can tell by the numbers on ligit bulbs, sparkplugs, etc. Is there any designation on a cap that you if it's the right or wrong one?
Hi Roger,
I was curious as to how to test also.
What I found was that you mount the capacitor on a Digi-Bridge LCR Meter and test for storage capacity and leakage profile.
I have no idea what that means!!!
Merry Christmas!
Regards,
Alan
PS: Some electrical savvy person step in please....
A poster at the NCRS board mentioned using a digibridge RCF meter, whatever it is. I'll check at work next week to see if the electricians have one. Also, there are several capacitors and I want to find out the ratings.
Hi Roger,
Merry Christmas!
Regards,
Alan
If you google "rc time constant" you'll get an explaination of how to measure a cap.
