How hard to remove POR15?
Old Jan 1, 2009 | 11:41 AM
IcemanZ06's Avatar
IcemanZ06
Default How hard to remove POR15?
I'm sure someone is going to ask "why would you ever want to remove POR15 if done right?" but the reason I'm interested in how hard it is to remove is because I'd like to treat some areas of my frame in the near future to prevent any further rust but would be performing a full frame off restoration later down the road (much later) and would like to be able to strip/repair/reseal the frame properly at that time.
So is this stuff impossible to remove or does media blasting take care of it?
Old Jan 1, 2009 | 11:52 AM
Droshki's Avatar
Droshki
Not having personal experience with POR, but from what I have read:
I would not do this. From what I have read, if you even slop POR on the lip of the can and put the lid back on, you'll never get it back off again. I can only imagine how difficult it would be to remove after properly applied to a surface. If you are only going for a temp solution, I would get an epoxy primer and a good topcoat for this temporary solution. Cost you about $100 for a quart of each, which goes quite far after you thin it to spray.
I also have stayed away from POR because of its UV sensitivity and need of an additional topcoat over it, but to each his own on that one I guess. I am sure that you will get a lot of good reports on it.
Old Jan 1, 2009 | 11:56 AM
MotorHead's Avatar
MotorHead
From: Who says "Nothing is impossible" ? I've been doing nothing for years.
You can get the lid off, takes about 1/2 hour though and the can is trash
I would not like to try and remove that stuff, probably near impossible but someone has probably done it
Old Jan 1, 2009 | 12:00 PM
Droshki's Avatar
Droshki
I love the voice of experience....
Old Jan 1, 2009 | 12:15 PM
cv67's Avatar
cv67
St. Jude Donor '05
Motorhead
Youll have to sandblast it off, its tough stuff. I tried doing a differential (brushed it on) while it was on the car many years ago trying to avoid a frame off. Long story short the body came off, the rearend...I took it to a sandblasting place. They tried to charge me extra and accused me of lying about it being painted and not powdercoated
Good stuff.
Old Jan 1, 2009 | 12:52 PM
Go Vette Go's Avatar
Go Vette Go
2024 C3 of the Year Finalist- Unmodified
St. Jude Donor '10-'11, '15, '19
Last winter, I decided to powder coat a couple parts that I had applied POR15 on. Impossible in my blasting cabinet with medium grit aggregate! I ended up using a aircraft paint remover then using the blasting cabinet for final cleaning.
Man, that stuff if TOUGH!
Old Jan 1, 2009 | 12:57 PM
rosslato's Avatar
rosslato
Old Jan 1, 2009 | 03:27 PM
Alan 71's Avatar
Alan 71
Hi Ice,
I believe there are many products that will give you enough protection until you're ready to 'restore', but will easier to remove at that time.
Wasn't POR-15 developed for severely rusted metal that couldn't be properly cleaned? Do you need something that serious?
Happy New Year!
Regards,
Alan
Old Jan 1, 2009 | 05:41 PM
72LS1Vette's Avatar
72LS1Vette
Try using Eastwood's Rust Encapsulator. It will give good protection for now and probably well into the future, and will be much easier to remove than POR when the time comes.
Rick B.
Old Jan 1, 2009 | 07:00 PM
Paul L's Avatar
Paul L
A small cold chisel, a hammer, and a lot of time will do that job.
Old Jan 1, 2009 | 08:36 PM
globey's Avatar
globey
put in a big oven and set at 900 degree..it will burn por 15 off
there is a place in dallas, texas that do all that..they are into powder coat too
Old Jan 2, 2009 | 07:04 AM
spikebot 81's Avatar
spikebot 81
A right angle grinder is the only way I've found to remove por15
Old Jan 2, 2009 | 08:13 AM
Nemesis_152's Avatar
Nemesis_152
you can just use ospho and some paint for a temporary solution
Old Jan 2, 2009 | 03:49 PM
bj1k's Avatar
bj1k
One of my customers was told by a company rep. for por-15 that the stuff was designed to bond only on rust not sand blasted metal. I don't know if anyone tried it on anything but rusted metal, but he said on anything else, it would eventually peel. Personally, I don't like the stuff. I believe the only way to do it right is to sandblast the metal and powdercoat or epoxy prime and paint.
Old Nov 8, 2010 | 03:51 PM
Kens_62's Avatar
Kens_62
Default I'm having POR15 regret, but now what?
Yeah, I bought into the who POR15 deal big time when I first started my project. Blasted frame, coated with POR15 and a couple of top coats. Now I am having buyer's remorse. Talking about kicking myself in the butt. I figure it will likely wait until I have the body back on her and ready to drive before it starts peeling. Until that time, I'm hosed.
Ironically, I just found out from a local PC guy that he would have done the the frame (62 vette) job for around $500.00. Another guy quoted $1500 and it was that price that convinced me to go with the POR15.
I would love a do-over on this one. Oh, the local PC guy says he can remove POR15 using plastic bead. Hard to believe, but he says he has done it for others who have taken the wrong path. No cheap at $125.00/hr, but it can be done.
Old Nov 8, 2010 | 04:12 PM
wcsinx's Avatar
wcsinx
That is correct. If you spray it on clean metal, it will peel off. It needs rust to "bite" properly. They also sell a product for etching clean metal which will allow the POR15 to stick to it, but that just seems bass ackwards to me.
Old Nov 8, 2010 | 04:34 PM
eastltd's Avatar
eastltd
Originally Posted by Droshki
I also have stayed away from POR because of its UV sensitivity and need of an additional topcoat over it .
How often is the bottom of your car exposed to sunlight?
To How hard to remove POR15?
Old Nov 8, 2010 | 08:26 PM
Indiancreek's Avatar
Indiancreek
Just get it on you and see how long it takes to get it off your hands. You can carve it off if you aren't fond of your skin.
Old Nov 8, 2010 | 08:33 PM
ZoraC3's Avatar
ZoraC3
Old Nov 8, 2010 | 08:46 PM
mar's Avatar
mar
I have a half-empty can of POR-15 in the garage fridge' now. Lid comes off very easily everytime I want to use a little. Secret:
Clean both lid and can mating areas with a cloth and a screwdriver tip pushing the cloth down in the lip valley and clean it out pristine or use q-tips before re-installing the lid. Then - turn the can upside down - place in a big zip lock bag and put in fridge. Keeps forever.
Just gotta' remember that it is very thick and sluggish until it warms up
