400 block in my 68?
Old Jan 7, 2009 | 04:53 PM
GeorgeS's Avatar
GeorgeS
Default 400 block in my 68?
I have a 68 with the original 327 / TH400.. If I were to replace the engine with a 406 (and put the 327 on a stand) how nicely would it fit? Anything in the way? Mounts fit? Is the 400 block heavier? Suspension issues...
Thanks for the help
Old Jan 7, 2009 | 06:38 PM
SteveG75's Avatar
SteveG75
Small Block Chevy = Small Block Chevy
Everything should bolt up just fine. Just expect that a 406 will put a bigger stress on your cooling system and driveline so make sure those are all up to par.
Old Jan 7, 2009 | 06:41 PM
SH-60B's Avatar
SH-60B
Externally the small blocks are dimensionally identical.
Old Jan 7, 2009 | 07:34 PM
7T1vette's Avatar
7T1vette
That should be a nice combination for a powertrain, and the THM400 is plenty beefy for the power of a 406.
Old Jan 7, 2009 | 10:27 PM
427V8's Avatar
427V8
C6 the C5 of tomorrow
I have a 400 bored and stroked to 434
Can't tell it from the outside at all.
But you can sure tell when the green light comes on!
Old Jan 7, 2009 | 11:53 PM
Gale Banks 80''s Avatar
Gale Banks 80'
The 400 Block has bigger Bores so less metal so the Block weighs less than a 327. Though not enough to make any diffrence in a street car.
Old Jan 9, 2009 | 12:06 AM
markdtn's Avatar
markdtn
Bolts right in. 400 balancers are large and can interfere with power steering. But not an impossible problem.
To 400 block in my 68?
