engine wire harness
Old Jan 17, 2009 | 01:47 PM
bobio777's Avatar
bobio777
Default engine wire harness
I pulled the engine on my 72 coupe, a couple of the wires around the starter are fried. I'm considering a new harness, how hard is it to remove and install at the fuse block?
Old Jan 17, 2009 | 02:45 PM
Durango_Boy's Avatar
Durango_Boy
Those wires that fried are probably the fusible links. You can replace just those, which are there to protect the rest of the harness.
Old Jan 17, 2009 | 03:04 PM
69Vett's Avatar
69Vett
Corvette of the Year Winner 2017
2016 C3 of Year Finalist
at the fuse block unscrew the 7/16 Nut/Stud and pull it off. easy.
But I would recommennd properly repairing your current harness,
if it is in decent shape.
69VETT
Old Jan 17, 2009 | 03:44 PM
bobio777's Avatar
bobio777
Thanks, I'll just solder in new wire where required, I was somewhat scared by the sellers of the wire harness who said the life of the original wires were ten years.
Old Jan 17, 2009 | 04:21 PM
Alan 71's Avatar
Alan 71
Hi B777,
It sounds like a repair is a good idea.
I think the reason the harness people said what they did is that the engine harness 'lives' in a tough place because of the engine heat and gas/oil atmosphere.
If you decide to change it someday it's not too big a job at all.
Regards,
Alan
Old Jan 17, 2009 | 10:23 PM
markdtn's Avatar
markdtn
I would get a new harness. Get a 'Lectric Limited from Last Detail. It will be easier to install with engine out. Harness is almost 40 years old with all that engine heat, cold, salt, rain, etc. Engine harness 1/2 is not that expensive. Really both are not bad moneywise, but the light harness is more and harder to install if you keep the fiberoptics. You can repair it, but with the engine out I'd replace it.
To engine wire harness
