Valve cover plaque
Old Jan 21, 2009 | 06:45 PM
john roth's Avatar
john roth
Default Valve cover plaque
I had to flip my valve cover end for end because the breather wouldn't fit under the wiper door actuator on the passenger side. Now the "Edelbrock" is upside down. I am thinking a plaque glued on with a simple "Corvette" stamped or engraved would be a good fix. Any idea were I might find such a plaque or even a better idea ?
Old Jan 21, 2009 | 07:07 PM
AcidShizno's Avatar
AcidShizno
Cruising
Why don't you just pick up a new "Stingray" fender emblem or a set of crossed flags for the front or rear of the early models and grind off the posts that go into the body? Glue that to the valve covers, it'd look pretty boss.
Old Jan 21, 2009 | 08:24 PM
john roth's Avatar
john roth
That would look good, but they aren't big enough. I am no were near my car right now but I will guess 7" x 1.25 "
Old Jan 22, 2009 | 12:49 AM
john roth's Avatar
john roth
CAN SOMEONE WITH A L76 - 79 MEASURE THE HEIGHT OF THE LETTERING ON THEIR REAR BUMPER. THE ONE I NEED IS 8'' L X W
(thanks Acidshizno)
JR
Old Jan 22, 2009 | 09:44 AM
john roth's Avatar
john roth
I would do it for you
Old Jan 22, 2009 | 10:07 AM
7T1vette's Avatar
7T1vette
I'm not familiar with those covers, but can you swap the right and left sides?
Old Jan 22, 2009 | 11:26 AM
spookytooth's Avatar
spookytooth
As far as the idea of the Stringray emblem, you can go to a metal supply house and get them to shear you the correct size alum. plate to cover the top of your valve cover. you could weld it to the top or drill and tap for some cool little button head screws - then attach your emblem to that.
Edelbrock makes several breathers that can be added to allmost any valve cover, consider a solid rubber plug for your current breather hole and add one of the others wherever you have room.
Old Jan 22, 2009 | 06:57 PM
john roth's Avatar
john roth
Good ideas, I will check them out. If I can simply swap sides you won't be hearing from me though :o
To Valve cover plaque
