Brake Line Armor
Old Jan 29, 2009 | 02:24 PM
GOLDEN65CPE's Avatar
GOLDEN65CPE
Default Brake Line Armor
Can someone identify whether the front cross over brake line running from the proportioning valve to the right brake Hose should have the spiral armor. Also the shorter line running from the prop. valve to the left brake hose. I know that the two lines running from the master cylinder to the prop valve should have the spiral armor. I recently purchased a complete set from In-Line Tubing and they say the armor should be present on those two front lines.
Old Jan 29, 2009 | 03:30 PM
Alan 71's Avatar
Alan 71
Hi G65,
I believe that the 2 lines from the master cylinder to the distribution block, the short line to the driver's side, and the long crossover line to the passenger's side all have armor.
I believe the rear crossover line doesn't have armor and the 2 hard lines on the rear calipers may or may not have armor depending on the year.
Regards,
Alan
Old Jan 29, 2009 | 05:56 PM
GOLDEN65CPE
Thanks Alan, Thats the answer I wanted to hear. Case closed
Originally Posted by Alan 71
Hi G65,
Regards,
Alan
Old Jan 30, 2009 | 01:44 AM
71coupe454's Avatar
71coupe454
all my lines were new and done just as above
To Brake Line Armor
