Please Check My Specs.
Old Feb 4, 2009 | 03:08 PM
Roarinbear's Avatar
Roarinbear
Default Please Check My Specs.
Could you review my cam and lifter specs. and tell me if I'm too close to the limits.
Heads have a max lift of .480
Cam lift is .462/.469
Roller Tip Rockers 1.52
Or will this combo work together.
Old Feb 4, 2009 | 04:17 PM
Durango_Boy's Avatar
Durango_Boy
Combo will work fine.
Using new springs I hope as opposed to use ones?
Old Feb 4, 2009 | 06:44 PM
Roarinbear's Avatar
Roarinbear
New heads
Planned build: 1975 L48 Top end
Summit #162109 Heads 62cc 170cc 2.02/1.60 Max lift .480
CompCams #CL12-238-2 XE262H 218/224/110 106* lift 462/469
CompCams Roller Tip Rockers #1412-16 1.52
I would like advice on this as well as head gasket thickness, and recommended gasket set. I'm planning this around a dished piston of 12cc-18cc. I can't seem to find accurate specs. I'm finding compression of about 8.8-9.4 with these heads, where should I be?
To Please Check My Specs.
