TH400 kick down switch , help!
Old Feb 7, 2009 | 04:16 PM
76projectstingray's Avatar
76projectstingray
Default TH400 kick down switch , help!
I think I have two issues.
The trans does not kick down all the time . I've checked the switch and can hear it click when I puch on the pedal. when I stomp on it the trans only downshifts sometimes.
when it does kick down it shifts back up really quick.
I did change the modulator to see if that would help. no change.
Any thoughts?
Old Feb 7, 2009 | 04:52 PM
glassman74's Avatar
glassman74
Any thoughts?
76,
On my 74, it will not kick down after 45-50 MPH.
glassman74
Old Feb 7, 2009 | 05:31 PM
baxsom's Avatar
baxsom
my 72 is the same way
once i am up around 50ish it wont kick down
Old Feb 8, 2009 | 12:52 AM
johnnybrewmeister's Avatar
johnnybrewmeister
Yep, same on my '73 - by design.
Old Feb 8, 2009 | 09:36 AM
7T1vette's Avatar
7T1vette
If the governor pressure level in your tranny is above a specific value when you try to "kick it down", the shift can't be made. That feature is a 'safety' protocol to prevent the tranny and engine from over-revving. It wasn't a very precise setting...determined by spring pressures in the valve body control circuit...so some cars wouldn't downshift when it was still 'safe' for them to do so. To test your downshift system, just set your speed at about 35 mph in "Drive"; then go to WOT. A downshift should occur in less than a second. If it does not, the downshift circuit is 'kaput' and the kickdown switch/linkage and/or the [internal] solenoid is defective. If it does downshift, the kickdown circuit is working as intended. {but maybe not just like you'd like it]
Old Feb 8, 2009 | 09:42 AM
76projectstingray
Thanks for the replys, This is the first time i've ever heard that it will not kick down over 45-50 mph. That stinks! I will try it today and see if that is the case, but i'm pretty sure most of the times i've been trying to get it to kick down i'm about 45 mph.
What about the fact that when it does kick down it usually wants to goes back to 3rd?
Old Feb 8, 2009 | 09:56 AM
'75's Avatar
'75
Does a shift kit include a different spring so it can be kicked down at a higher speed ?
Old Feb 8, 2009 | 12:45 PM
7T1vette's Avatar
7T1vette
Actually, I believe that the Chevrolet Chassis Service Manual has a chart in it which gives the shift points [tolerances, anyway] and downshift points for your car in MPH. This could help you diagnose if you have a problem or not.
Your tranny will kickdown into 1nd gear, but only if the engine can handle that downshift speed. (i.e., try kicking it down when you are going 20 mph at steady speed and has only shifted into 2nd.)
To TH400 kick down switch , help!
