Intake gasket question
Old Feb 9, 2009 | 08:16 PM
dmayhew's Avatar
dmayhew
Default Intake gasket question
I would like to know how many of you use the rubber front and rear intake gaskets and how may use just a RTV type sealant only.
I am workinh on a 350 with aluminum intake.
David
Old Feb 9, 2009 | 08:29 PM
C3 Stroker's Avatar
C3 Stroker
I always just use a bead of RTV type sealant.......never leaks. I used the intake gaskets once (years ago) and it soon leaked ......maybe others have had better luck with them.
Old Feb 9, 2009 | 08:31 PM
Gordonm's Avatar
Gordonm
Large bead of RTV here. No leaks in many engines built this way.
Old Feb 9, 2009 | 08:35 PM
tnovot's Avatar
tnovot
I also used the rubber gaskets for front and rear seals several years ago. Never again. Have used RTV since with great success.
Terry
Old Feb 9, 2009 | 08:45 PM
dmayhew's Avatar
dmayhew
Thanks to all
3 for 3 , do not use the gaskets
David
Old Feb 11, 2009 | 06:57 PM
straub18045's Avatar
straub18045
good bead of gms (general motor silicone) available at your local gm parts counter
Old Feb 11, 2009 | 07:14 PM
hgm's Avatar
hgm
Always use Silicone
Old Feb 11, 2009 | 11:53 PM
71coupe454's Avatar
71coupe454
maybe 10 years or ago I tried useing the seals and the pushed out when I tigntened the intake bolts down. I glued them down with yellow weather strip adhesive first then put the intake on. still in there and still leak free.. bubba got lucky? I didnt know then I could leave then out.
Old Feb 12, 2009 | 01:14 PM
Jeff_Keryk's Avatar
Jeff_Keryk
Do a dry fit with the port gaskets only. Visually check the front and rear mating surfaces. As long as the surfaces align (and they should!) silicone is your best choice. I had a problem on a 65 Olds 400 with an Edel Performer (rear mating surfaces did not align correctly) that required using the rubber end seals and silicone, but never on a Chevy.
Old Feb 12, 2009 | 01:35 PM
DRIVESHAFT's Avatar
DRIVESHAFT
I always use silicone now days.
Years back I used the rubber or cork seals, and honestly have never had a problem with them either way.
To Intake gasket question
