Sealing help
Old Feb 11, 2009 | 03:01 PM
Blown 79's Avatar
Blown 79
Default Sealing help
What is the material used to seal under the chrome t shaped trim that the T Tops ride on.
Old Feb 11, 2009 | 03:34 PM
wombvette's Avatar
wombvette
You are not likely to find the exact same stuff, but automotive seam sealer is a good substitute.
Old Feb 11, 2009 | 04:23 PM
Blown 79's Avatar
Blown 79
Thanks. Will this material work around the ends of the weatherstriping and to seal between the stainless trim pieces that go around the tops?
Old Feb 11, 2009 | 09:16 PM
wombvette's Avatar
wombvette
Yes, it will do and maybe some strip caulk, if you want more body.
Old Feb 11, 2009 | 09:26 PM
70Yellowbird's Avatar
70Yellowbird
The product some of the other posts are referring to is a box of 3M Strip-Caulk. It's black in color and never hardens ... sold at NAPA, and many other automotive supply stores.
Old Feb 12, 2009 | 08:42 AM
Blown 79's Avatar
Blown 79
Thanks Guys I found the product this morning and it's just what I needed.
To Sealing help
