17" wheel tyre size?
Old Feb 24, 2009 | 05:04 PM
77vetteuk's Avatar
77vetteuk
Default 17" wheel tyre size?
Look at buying a set of Torque thrust II's for my '77
17" X 8" all round
What tyre size are you guys with this size wheel running?
Cheers
Old Feb 24, 2009 | 06:08 PM
aaroncorvette's Avatar
aaroncorvette
I've got 245/50/17 pirelli p-zero on the front with 8x17 and 255/50/17 federal s595 (great tred pattern) on the rear on 9x17,but i'm putting the Federals all round soon, the pirelli's are ok but the Federals are great, loads of grip in the dry and rain and light years ahead in the handling department than the 15's , they were only £150 a pair (approx $210 ), i'm not sure if you can get them in the states,
IMHO it's a nice sidewall compromise, not too tall and dated and not too rubber band looking, i fact it looks like how the vette should have come from the factory
Look in my gallery or if you go to Vintage Wheel works and look at the GM photo gallery it was the first car on there (red '71 'vert).
17" tyre choice is quite limited, which is why most people use 18", but there are tyres out there, you just have to look, Go to TireRack and find the high performance tyres, yokohama also make an advan 255/50/17, its an sport |SUV tyre (like my Federals), don't let that put you off, there's more grip there than most c3's will ever need!
Good luck.
Old Feb 24, 2009 | 06:14 PM
aaroncorvette
Ahh.. i've just noticed you're a fellow ale drinking Englander
are you on the CCCUK website?
Old Feb 24, 2009 | 06:33 PM
gkull's Avatar
gkull
17X9 with 255/45 are good
Old Feb 24, 2009 | 06:47 PM
angelthrust's Avatar
angelthrust
17" X 8" all round
Cheers
got pics?
Old Feb 24, 2009 | 08:18 PM
StickShiftCorvette's Avatar
StickShiftCorvette
I run Goodyear Eagle F1s 245ZR45-17s. I ran 255ZR40s before this set.
Old Feb 24, 2009 | 09:13 PM
zwede's Avatar
zwede
255/50-17 will have the same overall diameter as stock and fill the wheel-well. You may have some slight rubbing in the front though at close to full lock. The fender lips can be trimmed to fix it (not really noticeable).
Old Feb 25, 2009 | 11:30 AM
Kevins77's Avatar
Kevins77
Good wheel choice! I have the same wheels on mine.
I run 235/45/17 on the fronts and 245/50/17 on the rears. I have no rubbing issues in the front and it looks very sharp.
Old Feb 25, 2009 | 01:58 PM
AD2VET's Avatar
AD2VET
CI 2-3-4-5-6-7-8-9-10 Vet
St. Jude Donor '09-'10
I'm thinking of the same thing and will probably go with 245/45-17s all around. They're the stock tire for the front of a C5 so there's plenty of brands, including RFs.
Old Feb 25, 2009 | 02:49 PM
jb78L-82's Avatar
jb78L-82
I have 255/45/17 ZR Kuhmos in the front and 255/50/17 ZR's in the rear to maintain the same overall diameter in the back on SLP's rims. make sure that you get Z rated tires. You will not be disappointed. Stay away from S/T rated tires if you want the ultimate performance.
Old Feb 25, 2009 | 06:25 PM
HBZ_81_C3's Avatar
HBZ_81_C3
I just ordered Centerline Splitspokes for my 81. 17X8 fronts and 17X9.5 for the rear with Nitto 555R tires, 255 front and 285 rear.
Old Feb 25, 2009 | 07:16 PM
timgman's Avatar
timgman
Default I wish I had a common...
I wish had a common right now!!
Old Feb 25, 2009 | 09:45 PM
DC3's Avatar
DC3
I'm running 235/55-17s on my 17 x 8's. This tire size gave me the correct height for my speedo to be reasonably accurate.
DC
Old Feb 26, 2009 | 01:15 AM
scottyp99's Avatar
scottyp99
I have a 1980 'vette, and am also looking into 17" x 8" rims. The stock tire size on my car is 255/60/15, and after doing some research, I found out that 255/50/17 tires have virtually the same diameter, so they won't change your speedo reading or anything. I am not sure about the availability of this tire size, however.
Scott
Old Feb 26, 2009 | 07:11 AM
jb78L-82's Avatar
jb78L-82
Scott
Please see my response above about using 255/45/17's and 255/50/17's, Kuhmo ECSTA SPT's, ZR's, available at Tire Rack for a very resonable price.
Old Feb 26, 2009 | 03:05 PM
Mr. Beam's Avatar
Mr. Beam
TT2 17 x 8" with BF Goodrich G-Force Sport 245/45/17 all around...
To 17" wheel tyre size?
