Z-Bar
Old Feb 25, 2009 | 10:24 PM
81cali's Avatar
81cali
Default Z-Bar
This may have been asked before, when swapping tranny to a 4 speed what and where is the infamous Z-Bar connected to? Pics appreciated. I have a helm corvette shop manual but is no where indicated.
Old Feb 25, 2009 | 11:02 PM
71coupe454's Avatar
71coupe454
it pivits on 2 ball studs, 1 in the block by the oil filter and 1 on the bracket on the frame under the mastercylider.
Old Feb 25, 2009 | 11:46 PM
81cali's Avatar
81cali
Is this it???
Old Feb 26, 2009 | 08:25 AM
jnb5101's Avatar
jnb5101
yes. get the bolt on frame bracket. set the pedals, engine stud and the push rod in place. then position the z-bar so that the pedal push rod lines up with the firewall hole. the z -bar will come off the engine in a more or less perpendicular line. that will show you where the bracket has to be positioned.
Old Feb 26, 2009 | 10:41 AM
spedaleden's Avatar
spedaleden
Hope this helps
Old Feb 26, 2009 | 12:02 PM
81cali's Avatar
81cali
Thank you very very much!!!!!!!!!!!!!
Old Feb 26, 2009 | 03:38 PM
81cali's Avatar
81cali
Is the Z-bar an actual part for stock manual tranny vettes or is this something that's needed when doing a swap?
Also, are there existing holes for the pedals? How about the manual shifter's place?
Old Feb 26, 2009 | 04:09 PM
spedaleden's Avatar
spedaleden
Z bar is part of a manual transmission assembly from the factory. It is also needed when doing a swap
You swap out the auto pedals for manual pedals. Check out Keisler Trans web site. They make a kit to swap out an auto to manual. This will answer a lot of your questions. I would also call them, great guys.
I beleive when you swap from auto to manual the factory opening for the shifter (Auto) will have to be enlarged. Do a search plenty of guys have swapped out auto to manuals
Old Feb 26, 2009 | 04:16 PM
TheFinn's Avatar
TheFinn
Is the frame bracket available somewhere?
Old Feb 26, 2009 | 04:28 PM
dobroman2001's Avatar
dobroman2001
Here's some pics of my '76. The holes for the pedals (and clutch rod) were already there.... they have a firewall "plug" on them..
http://s189.photobucket.com/albums/z...20to%20Manual/
Old Feb 26, 2009 | 04:55 PM
Go Vette Go's Avatar
Go Vette Go
2024 C3 of the Year Finalist- Unmodified
St. Jude Donor '10-'11, '15, '19
I believe 80 & 81 already have the holes drilled in the frame for the Z-Bar bracket. Here is the bracket you will need -> http://www.zip-products.com/Zip/prod...CD040A78D92C7C
I used this on my 78 when I converted from auto to manual.
John
Old Feb 26, 2009 | 07:20 PM
glen242's Avatar
glen242
Do yourself a favor, before you install the 4-speed, get a Hurst Comp+ shifter. Or, install the 4-speed with the stock shifter, and after you experience the "positive shifting" of the stock unit, buy the Hurst and spend a bit of time installing it with the transmission in the car.
Old Feb 26, 2009 | 07:53 PM
jnb5101's Avatar
jnb5101
if you go with the standard corvette shifter, the opening in the tunnel will have to be made smaller. get the lower shift boot and center it on the shift lever, and you will see where you have to add glass. not a big job.
Old Feb 26, 2009 | 08:44 PM
81cali's Avatar
81cali
this is what I have
Old Feb 26, 2009 | 08:48 PM
81cali's Avatar
81cali
saw you pic, THANK YOU! they were very helpful. What about the hole for the manual shifter, will my existing hole from the auto be substantial?
Old Feb 26, 2009 | 09:43 PM
dobroman2001
I just posted a couple more pics that show the Auto Shifter and then it replaced with the Manual Shifter. You will be able to see the hole that I had to cut (yep, my Auto '76 has the steel compartment so it had to be cut!!). I think I just cut the recessed area wher the Auto shifter fit. You can do a search for this on the Forum and I think guys have the exact measurements..
Good Luck - It actually isn't that bad!!
Old Feb 26, 2009 | 10:14 PM
81cali's Avatar
81cali
AWESOME!!! Now my problem is the Z bar bracket that attaches to the frame........dang, I thought I had everything
Do you think the swap can be done in one day? Reason is, my friend who works at a shop is willing to assist and use the hoist but only on Sundays and the car has to be out same day.
To Z-Bar
Old Feb 26, 2009 | 11:01 PM
81cali's Avatar
81cali
John
John,
Is this a dealer item? I just want to be able to get it same day and zip is no where near where I am.
Old Feb 27, 2009 | 07:45 AM
Go Vette Go
John,
Yes - it was a stock item. Other vendors have it - dealers might have it.
John
Old Feb 27, 2009 | 08:36 AM
TheFinn's Avatar
TheFinn
Thanks for the info.
Hmmm, I only have the Z bar and one ball stud for block. Apart from the frame bracket can rest of the parts around the bracket be bought somewhere?
