Pressurized brake bleeder mods
I haven't put it to use in an actual bleed, but I have dry fitted it and it definitely does not leak. The only down side I see so far is that I have to remove the check valve fitting on the vacuum booster to get it to fit, but it just plugs in so that's not too bad.
What do you think?
Dave
But it is very nice. Got some good skills there. Why not just notch it for the check valve, or better yet, change to a hydro-boost?
Whats with those odd looking nuts? They look open on one side.
Next step you could take is to dip the U-bolts into conformal coating, the kind that you use to coat some tools -like a chisel shaft or screwdriver shaft. That will keep the paint on your MC from scratching.
Then, I agree with above, when you done with that, convert over to Hydraboost.
Those "odd looking nuts" are a type of quick opening nut, so that I don't need to thread them down the entire length of the u-bolt.
Thanks for your compliments.
Dave
That may be the next upgrade. When I have time.
Dave
http://picasaweb.google.com/lh/photo...eat=directlink
I have the Ammco commercial bleeder and even it has problems. The cheesy chains stretch out on you and always at the wrong time. Combine this with the generic rubber seal that is way to thin and wears out way to quick and you can have a mess. The Ammco is so bad at leaking that before we install it we put a piece of plastic down on the column and then a towel every time.
There is nothing better than using a pressure bleeder, but they are a pain everytime they are used.
I’ve been trying to think of a better mouse trap for it that would be more dependable and by gosh I think he’s got it. Nice job!
Willcox
This link shows mine very simple to build. Yours is much better looking than mine is.
For us this is not an option since we use this on the 63-67 cars (which have six different master cylinders) and we use it for the 58-62 cars.
We need a nice firm thick plate like pictured with a good flat gasket that can adapt to different cylinders.
The cap design would work great for the 67-82 cars, but another plate would also need to be made for the single res. cars. I guess this may explain the chain system supplied with the Ammco bleeder.
Willcox
Tried that,
The gasket sucks, needs to be thicker, wider.
The one I made even had tubes down into the reservoir to lower the fluid level before disconnecting in an effort to reduce any mess.
Worked great first few times and as long as it wasn’t pressurized for more than 5 minutes. Cleaning that mess wasn’t worth it.
Ended up making 1 similar to above out of ½” alum with only 1 coupler and a slot milled between the 2 cavities. Use a large vicegrip clamp. No leaks and fast and easy.
Still in search of a better gasket material.
Willcox
When getting to the bleeding part of brakes, it should be the part you really look forward to, since all the PITA work is over, and you want to reward your good work by having perfect brakes and not dread it because it is a whole new PITA.
Stupidly, I got rid of an Ammco bleeder years ago for next to nothing, didn't realize how expensive they were.
Here are some "over the top adapters" and their chains DO work but a little pricey.
These will work on all older domestics.
The Power Probe has my vote for being one of the best tool in decades.
http://www.powerprobe.com/powerprobe/Home.html
Best prices I found when I got mine was eBay.
Just top off the MC after each bleed location and you'll never have to worry about the MC running dry and never have to worry about brake fluid leaking all over your car.
