68 loose steering
Old Mar 1, 2009 | 07:53 PM
ed68's Avatar
ed68
5th Gear
Default 68 loose steering
The steering on my 68 has free play.When holding the steering shaft above the rag/flex joint and turning the steering wheel, the wheel turns but the steering shaft does not. It is not drastic but enough that it can be felt when driving. BTW am new to this and this is my first post! Look forward to helpful info
Old Mar 1, 2009 | 09:37 PM
wombvette's Avatar
wombvette
If you are saying that the steering wheel actually moves and the shaft above the rag dont, you had better get that thing looked at. It shouldnt do that, and is very likely dangerous.
Old Mar 2, 2009 | 11:23 AM
Kevins77's Avatar
Kevins77
Are you trying to say there is a little play in the wheel before it starts turning the shaft, or that its not turning the shaft at all?
Old Mar 2, 2009 | 11:57 AM
cargo247's Avatar
cargo247
you need this link
http://jimshea.corvettefaq.com/?page_id=4
Todd
Old Mar 2, 2009 | 12:06 PM
Derrick Reynolds's Avatar
Derrick Reynolds
St. Jude Donor '13-'15, '17 thru '22
Welcome to the forum!
Like Wombvette, I am not sure I understand your post. Jim Shea's papers are definitive for Corvette steering diagnosis and proper repair. They are also sufficiently well-written that the weekend mechanic (like me) can understand them. Lars also has a paper in the archives on adjusting the lash on your steering box which is very good and easy to follow. I found the search function here to be non-intuitive, and it took me a while to figure out how to find what I wanted, but the effort was definitely worth it.
Old Mar 2, 2009 | 07:12 PM
ed68's Avatar
ed68
5th Gear
Default 68 loose steering issue
Apologies for a confusing post, failed to mention it is telescopic,and power, yes the steering wheel turns a bit, but the shaft above the rag joint does not. This leads me to believe that the issue has to do with the splines of the shaft and the "tube" that surrounds it. And yes Jim Shea's papers are a great help.Has anyone experienced the same issue and found a resolution ? Thanks
Old Mar 2, 2009 | 11:49 PM
Jim Shea's Avatar
Jim Shea
When you push and pull on the steering wheel does the steering shaft move at all when you have it locked ? I am wondering if the telescoping feature does not lock sufficiently, you could get some twisting looseness as well.
Otherwise, the looseness is most likely in the section of steering shaft that has plastic injection to prevent just the type of motion you are complaining about. This will require disassembly of the steering column.
I have two recent papers that I authored on the 1967-68 Corvette telescoping steering columns. Hopefully they can help:
http://jimshea.corvettefaq.com/wp-co...ev23ja2009.pdf
http://jimshea.corvettefaq.com/wp-co...v-23ja2009.pdf
I am on vacation so I will not have internet access every day.
Jim
Old Mar 3, 2009 | 12:34 AM
wombvette's Avatar
wombvette
I have seen that ball broken or worn and will cause this movement.
Old Mar 3, 2009 | 07:35 PM
ed68's Avatar
ed68
5th Gear
Thanks Jim, your papers are a fantastic resource. I will be disassembling the column to locate and fix the problem and the papers will be of great help. Thanks again and enjoy your vacation.
Ed68
Old Mar 5, 2009 | 07:42 AM
Jim Shea's Avatar
Jim Shea
With a telescoping steering column there is only one place in the steering shaft itself where you could develope lash. That is the telescoping joint itself and it may not be locking the upper steering shaft to the lower tubular shaft so that it eliminates any lash when you rotate the steering wheel. There is a star screw, a rotating adjusting lever, a long rod, and a locking wedge.
In the 1967-68 Telescoping Steering Column Paper #1 there should be a description on adjusting the telescoping feature. Read that part of the paper and try to adjust the rotating lever so that the shaft won't telescope and possibly eliminate the rotational lash as well.
Now, it is also possible to have bad steering shaft bearings that might give the indication of rotational lash. But I would try the telescope adjustment procedure first.
Jim
Old Mar 6, 2009 | 05:26 PM
ed68's Avatar
ed68
5th Gear
Thanks, valuable info, will try the adjustments first, as of now it is not locking. Again, everyone, thanks for the info. It will be great when I can resolve this long lived problem and again enjoy the ride.
Old Mar 6, 2009 | 10:11 PM
Jim Shea's Avatar
Jim Shea
If the telescoping feature is not locking, you WILL have rotational slop when you rotate the steering wheel as well.
Jim
Old Mar 10, 2009 | 09:05 PM
ed68's Avatar
ed68
5th Gear
Thanks, will try adjustments in the near future and post results. Thanks again for the info.
To 68 loose steering
