72 Starter ground cable?
Old Mar 2, 2009 | 01:21 AM
avner's Avatar
avner
Default 72 Starter ground cable?
The thick starter ground cable goes from the engine mount screw to the starter, where I connect the ground on the starter? (Pic' will help).
Thanks, Avner
Old Mar 2, 2009 | 01:35 AM
noonie's Avatar
noonie
Old Mar 2, 2009 | 10:14 AM
joewill's Avatar
joewill
yes, that is the engine to frame ground, since the battery is grounded at the frame, this completes a high amp current path from your starter back to your battery..
Old Mar 2, 2009 | 10:37 AM
Alan 71's Avatar
Alan 71
I believe the AIM shows a large 'star' washer between the connector and the starter bracket and at the other end between the connector and the frame. I guess the star bites into the connector and mount so there is a sure ground.
Regards,
Alan
Old Mar 2, 2009 | 12:33 PM
avner's Avatar
avner
Thanks for the replies.
I'm missing that bracket, because of that I didn't saw a hole/screw to connect the cable to it.
Old Mar 2, 2009 | 04:01 PM
DZRick's Avatar
DZRick
That's a heat shield and your car may not have had one to begin with.
Old Mar 2, 2009 | 04:33 PM
eastltd's Avatar
eastltd
I deviated a little on mine. Here is the mini-torque starter connections:
To 72 Starter ground cable?
