Chrome breather
Old Mar 2, 2009 | 03:46 PM
ANY VETTE's Avatar
ANY VETTE
Default Chrome breather
Just got a chrome breather but I don't know what to do with the oil breather hose leaving my valve cover that went into the old breather?
Old Mar 2, 2009 | 03:57 PM
wfo76's Avatar
wfo76
Street engine? Forget the chrome breather and leave the factory PCV system in place.
Old Mar 2, 2009 | 04:09 PM
ANY VETTE's Avatar
ANY VETTE
Why?i am going to disconnect the PCV as it is useless it is the oil vent hose?
Old Mar 2, 2009 | 06:48 PM
BassCat's Avatar
BassCat
I kept the PCV hooked up on the drivers side, and installed one of those chrome breather filters in the valve cover on the passenger side.
Old Mar 2, 2009 | 08:45 PM
MotorHead's Avatar
MotorHead
From: Who says "Nothing is impossible" ? I've been doing nothing for years.
You should swap the Breather and PCV, ( the grommets are interchangable as in the hole in the valve covers are the same size ) and then the PCV hose would only be a couple of inches long. If your worried about the look, Billet Specialties sells a cool looking billet polished aluminum pcv
To the original poster, all street motor should run a PCV system if only to keep oil residue off the valve covers
Old Mar 2, 2009 | 08:55 PM
toddalin's Avatar
toddalin
You should paint in the lines at the back of the alternator to match the covers and carry the theme.
Old Mar 2, 2009 | 09:32 PM
BassCat's Avatar
BassCat
Couple of good suggestions. I'll put 'em in the job jar for spring.
KC
Old Mar 9, 2009 | 05:03 PM
Drunken Peacock's Avatar
Drunken Peacock
I pulled my PCV out and put in a chrome breather. The hose runs to the base of your carb. Pull it off and cap it.
Old Mar 9, 2009 | 07:17 PM
7T1vette's Avatar
7T1vette
A PCV valve is a "good" thing. Keep it....
Old Mar 9, 2009 | 07:57 PM
GDaina's Avatar
GDaina
PCV valve replaced the vent tubes that were used in the first V-8's.
Old Mar 9, 2009 | 09:08 PM
08vycpe's Avatar
08vycpe
I did the same thing BassCat did. That way I have an active PCV and both sides can breath.
To Chrome breather
