Cruise control
Old Mar 8, 2009 | 12:25 PM
yel76low's Avatar
yel76low
Default Cruise control
I noticed that some later C3's have cruise control. What is all involved with that, and is it possible to retrofit to a earlier model year?
Old Mar 8, 2009 | 05:32 PM
TheSkunkWorks's Avatar
TheSkunkWorks
From: Graceland in a Not Correctly Restored Stingray
Basically, the speedo cable runs thru a transducer which controls a vacuum can linked to the carb which manages throttle position. You'd need the two speedo cables, the transducer, can, linkage(s), brackets, switch and some wiring skills. Also, the later C3's used a stalk for dim/highbeams, in the end of which was the cruise button. An AIM from a year (such as '78) with this option should show necessary details.
Some notes about operation: This system didn't have all of the usual on/off/accel/deccel/resume functions you might expect nowadays. You pretty much pushed the set button at the speed you wanted and disengaged with the brake pedal. Been so long since mine was functional (re-purposing the transducer), I can't remember if it accelerated as long as you held the button and set a new speed where you released it or not. I'd wire in a safety to avoid the engine revving if put out of gear. Hope that helps.
TSW
Old Mar 8, 2009 | 06:00 PM
1nicecorvette's Avatar
1nicecorvette
yeah its not the most accurate. set it and forget it. it will flucuate between 3-5 miles per hour up and down, it wont hold "exact" like todays cars do
Old Mar 8, 2009 | 08:33 PM
7T1vette's Avatar
7T1vette
It is quite possible to install a later year's cruise system on an earlier C3. But, for the cost and trouble and the quality of the cruise system, it's a lot easier to install an electronic aftermarket cruise unit. But, if you want it to be a Chevy system, go for it.
Old Mar 8, 2009 | 09:49 PM
couperdecar's Avatar
couperdecar
Mine wouldn't hold worth a damn. I tried adjusting it. Mechanic tried adjusting it. 60 mph accelerate to 70 mph, decelerate 60 mph accelerate to 70 mph..... Like a bloody roller coaster. It was useless. Couldn't use it without getting sick and using a ton of gas.
When I switched out to Vortec heads, I threw all the parts in the bush. (that pile in the bush is growing )
Someday I made add modern cruise.
Old Mar 8, 2009 | 11:44 PM
pleasants9's Avatar
pleasants9
yeah ive been real curious to adding some sort of cruise control system to my '82 the three hour drive from Stuart to Gainesville from home to college really wears out the foot.
Old Mar 9, 2009 | 12:18 AM
gingerbreadman1977's Avatar
gingerbreadman1977
i used to have cruise in my 81 . it used to operate very smooth except on 60 mph . it didnt know how to do that speed. it either wanted 65 or 55. any other speed was no problem but i changed carbs and cleaned out the engine bay. i didnt really use it very much and would even less now with a more angry motor.
Old Mar 9, 2009 | 07:16 AM
yel76low's Avatar
yel76low
Thanks for the info guys. I don't actually intend on doing it (there's many other things I'd rather do with that $500) I was just kind of wondering how it worked and if it was possible.
Old Mar 9, 2009 | 01:35 PM
7T1vette's Avatar
7T1vette
I think an 'add-on' electronic cruise unit will run you around $200.
To Cruise control
