NEw clutch not adjusting correctly
Old Mar 8, 2009 | 11:31 PM
dmayhew's Avatar
dmayhew
Default NEw clutch not adjusting correctly
I installed the 350 motor back into my 71 car last night and I have ran into a possible disaster, I am worried I may have to remove the motor.
I Installed a new ZOOM clutch. It is a basic upgrade from oem.
The old clutch had very little wear but I replaced since the motor was out.
The old set up had the adjusting nuts on the clutch rod about 2 to 3 inches from the end of the rod and about 1'" of free travel.
I have adjusted this new unit all the way to the end of the rod and I still have about 6 to inches of pedal free play before the pressure is felt.
I removed the boot and the fork is loose on the pivot ball.
When you mash the clutch a lot of the travel is being used to seat the fork dimple onto the ball, then the fork start to compress the fingers.
I have a fear that the pivot ball may be the issue. It is an OEM type.
I see that the allen head is accessable with the trans bolted to the bell hsg.
Is it possible to adjust or replace the pivot ball w/o removing the motor or trans?
It may also be something that someone that is more experienced with this couls fix easily. I am just freaking out that I may have to pull the motor back out.
DAvid
Old Mar 9, 2009 | 12:14 AM
AzMotorhead's Avatar
AzMotorhead
Limping across the line
I bet 1. you have a shorter throwout bearing and or 2. throwout bearing is installed incorrectly on fork.
Possibly even the clutch disc is in backwards
Old Mar 9, 2009 | 01:11 AM
dmayhew's Avatar
dmayhew
The disc was isstalled right. It had a sticker on it showing which side toward PP.
As for the throw out bearing. They look close. I will have to call Zoom to get a measurement and check for sure.
The old one measued the same thickness as the new one.
The fork is fully in the slot on the T/O bearing and the clip is behind the ball.
Its a mystery at this point.
Thanks for the assistance
David
Old Mar 9, 2009 | 08:38 AM
pws69's Avatar
pws69
Yep, new pivot ball required. Adjustable ones are preferred, then you can get it right on.
Old Mar 9, 2009 | 09:45 AM
63mako's Avatar
63mako
St. Jude Donor '08-'09
http://www.clutch-shop.com/tips.htm#gmbrg
Or you need the adjustable or longer pivot ball
Old Mar 9, 2009 | 12:18 PM
jackson's Avatar
jackson
All above good tips to check into ... in addition though is this:
flywheels get thinner with use, especially when resurfaced/ground ... as it thins, pp mount surface moves forward and pp fingers move forward and tob also moves forward. This is not some pie in the sky esoteric hypothesis; it's real.
one solution: correction shim(s) are placed between flywheel & crank flange ... the shim moves the fw rearward; all related clutchpak dimensions also move rearward.
Because of this ... ready-to-use fw shims are purposely mfd for this application by several companies including "Pioneer". FYI, "Perfection Clutch" is parent of Zoom; they manufacture flywheels too and may also offer fw shims.
Old Mar 9, 2009 | 12:34 PM
bj1k's Avatar
bj1k
Pressure plates with high dome fingers take shorter throw out bearings and low dome fingers take long release bearings. They might have given you a short pressure plate with short bearing. If so , you will have to slide the trans back far enough to switch bearings.
Old Mar 9, 2009 | 02:34 PM
dmayhew's Avatar
dmayhew
Thanks for all of the input.
I called ZOOM. The 3006S clutch comes with a 1 1/4" height T/O bearing.
That matches to my old bearing removed.
Still chasing the problem
David
Old Mar 9, 2009 | 09:25 PM
BigBlockTank's Avatar
BigBlockTank
Just a note: Think of how far the pedal travels in relation to the clutch fork. The pedal travels 6-9 in., depending on the pedal and the car? The clutch fork moves......as little as 3/8"? Not doing the math for you, but half of that travel at the pedal would equate to approx. 3/16", not alot of travel. It doesn't take a whole lot for the adjustment to be off, and would seem to be alot off.
Old Mar 9, 2009 | 10:58 PM
dmayhew's Avatar
dmayhew
BigBlockTank, Thanks for the advice. I hope I found the culpret.
I was not aware that this spring helps keep the fork seated on the pivot ball.
A new one should be here tomorrow and I will try again. Also odered a new boot.
Man I hope this turne out to be a simple rookie oversight on the importance of this spring.
David
To NEw clutch not adjusting correctly
