Power antenna
Old Mar 9, 2009 | 07:35 AM
corvetteterry's Avatar
corvetteterry
Default Power antenna
I have a power antenna iam trying install ,buy it has two wires a blue and red athen the antenna wire.i have a blue wire that comes from somewhere that is hot. PLEASE HELP ABOUT TO PULL MY HAIR OUT
TERRY
Old Mar 9, 2009 | 09:55 AM
car71's Avatar
car71
The blue goes to the blue wire that come out of the back of the head unit, its called the remote wire.
Old Mar 9, 2009 | 10:01 AM
Theiskell's Avatar
Theiskell
What you are seeing is normal. Most power antennas have three wires 1 (black) goes to ground, 1 (red) goes to constant power, 1 (blue) goes to a remote wire from your radio.
When power is applied to the blue wire the antenna goes up. When you cut the power to the blue the red wire takes over and moves the antenna back down. If you don’t have a black wire I would guess it’s getting its ground from the case.
To Power antenna
