Hydroboost help.
Old Mar 10, 2009 | 03:52 PM
Kfmorgan's Avatar
Kfmorgan
Default Hydroboost help.
Not too long ago, I found installation instructions, along with the parts required to put my own Hydroboost system together. I believe that it also included all the lines and fittings that you would need. Now that I've decided that I want to do this conversion, I can't seem to come up with that article, in this forum, no matter how I search the forum. Anyone out there have a lead to that particular paper?
Thanks in advance for any info.
Old Mar 10, 2009 | 04:21 PM
Binnie77's Avatar
Binnie77
You have a PM
Old Mar 10, 2009 | 04:42 PM
RobRace10's Avatar
RobRace10
These may help.
http://forums.corvetteforum.com/c3-t...tings-pdf.html
http://forums.corvetteforum.com/c3-t...-fittings.html
Old Mar 20, 2009 | 08:53 PM
ROCKET2's Avatar
ROCKET2
4th Gear
I've just gone through 3 weeks of trying to get some answers on the hydratech. My problem that I just found out was with the pump. Pump should be between 2 and no more than 3.5 gpm around 900 to 1200 psi. Good luck directions I thought were a little confusing!
Old Mar 20, 2009 | 11:29 PM
chris75stingray's Avatar
chris75stingray
the toughest thing is hooking up to the power steering control valve. the 2nd link Robrace posted is what i did for the control vlave. i scrounged up some fittings i had lying around and bought a few more . it's probably not the best way but it's been working great
Old Mar 30, 2009 | 03:52 PM
ShaneLU97's Avatar
ShaneLU97
I noticed the rebound as well while testing the brakes after bleeding. I think that is what freaked me out the most.
I appreciate everyones feedback. Makes me feel better about droppping the rear of the kwiklift and getting her our on the road again.
Shane
To Hydroboost help.
