pass inspection
Old Mar 27, 2009 | 01:16 AM
MNTWINS33's Avatar
MNTWINS33
Default pass inspection
How do i know if my headers will pass emmision inspection?
Old Mar 27, 2009 | 01:27 AM
TheSkunkWorks's Avatar
TheSkunkWorks
From: Graceland in a Not Correctly Restored Stingray
Depends on how much power the econazis have in Minnesota.
Old Mar 27, 2009 | 04:56 AM
baxsom's Avatar
baxsom
usually any modification to the exhaust system is an automatic failure if they check for that stuff.
that being said
both my 72 vette and 68 mustang have headers and here in san antonio they dont even look at them.
Old Mar 27, 2009 | 07:44 AM
surfertom's Avatar
surfertom
Default headers
here in utah it depends on the year , i think 84 and newer require all the smog stuff to be on the car. i have headers on my 69 coupe and my 79 olds cutlass and they pass fine. if its the smog pump you have to have hedman makes a smog tube kit for headers for around $80.00. hope this helps. tom
Old Mar 27, 2009 | 08:03 AM
2manyvetts's Avatar
2manyvetts
If you registered them as antiques you are not required to inspect them
Old Mar 27, 2009 | 10:03 AM
7T1vette's Avatar
7T1vette
Go to the inspection station and give it a try. You'll either pass it or fail. If the latter, you'll be given info on why it didn't pass plus some time (10-30 days, depending on state) to get it 'repaired'. If they won't even test it with the headers on it, then you'll have to get them changed. But, I'd bet your car will be tested and, if it passes the emissions test, you'll be OK.
Old Mar 27, 2009 | 10:45 AM
rebbie23's Avatar
rebbie23
true, but different for every state
Old Mar 27, 2009 | 11:07 AM
MN-Brent's Avatar
MN-Brent
Im not aware of any inspection requirements or emmissions testing at all in Minnesota. That was all abolished maybe ~10 years ago.
So if you are in MN, no need to worry about anything really
B.
Old Mar 27, 2009 | 11:11 AM
VettePower's Avatar
VettePower
B.
Are you serious?? No inspections, period, for anyone or any year car??
Old Mar 27, 2009 | 10:07 PM
MN-Brent's Avatar
MN-Brent
Nada. Nothing. Zilch. All the emission inspection stations were closed many, many, moons ago. State budget didnt want to support it and studies indicated it made no positive effect on the air quality in our state. Most cars on the road are newer model with functional emissions systems.
I think if you are building a kit car, with no previous VIN, then you will have to get a safety inspection.
The only other way I can think of needing to get an inspection is if you get a "fix it" ticket from having a tail light out and somehow **** off a cop.
B.
Old Mar 30, 2009 | 12:16 PM
VettePower's Avatar
VettePower
B.
Amazing!!! You must have some monster cars on the roads!! On a side note though, you must have a lot of old POSs on the road ready to fall apart, or God forbid, brakes that won't work in an accident...
Old Mar 30, 2009 | 04:37 PM
markdtn's Avatar
markdtn
In Tennessee we have sniffer tests on 75-95 and OBD2 on 96 up. No safety inspections. Not all cities have that, only the ones in non-attainment zones.
Old Mar 30, 2009 | 04:48 PM
VettePower's Avatar
VettePower
So now I see how Jed Clampett's car was able to be street legal!!
Unfortunately, when he got to California, it wouldn't pass the smog tests....
Old Mar 30, 2009 | 04:52 PM
coolcoupe's Avatar
coolcoupe
well as far as i know there hasent been emissions inspections in mn for years now they did try but they give up
To pass inspection
