71 wiper door
Old Mar 11, 2009 | 11:46 AM
vetteguy60's Avatar
vetteguy60
8th Gear
Default 71 wiper door
The wiper arms on my 71 get pinched in the wper dood if I turn off on the up swing. I have replaced saftey switch, wiper solenoid,relay and check all hoses,and bypass switch. Mike
Old Mar 11, 2009 | 01:05 PM
wro87's Avatar
wro87
Have you replaced the small vacuum switch on the passenger side that is under the coverright below the pass. wiper arm this might be your problem becuse this is what controls the door and wipers so they work in sync.
Good Luck wro87
Old Mar 11, 2009 | 05:10 PM
Alan 71's Avatar
Alan 71
Hi Mike,
WRO87 is on the right track, the vacuum switch under the right arm can be adjusted so it doesn't signal the door it's O.K. to close until both arms are completly parked.
Are the arms adjusted so they park against the blade stop properly?
Regards,
Alan
Old Mar 11, 2009 | 08:48 PM
7T1vette's Avatar
7T1vette
Or...you might have the hoses connected improperly to that switch. The door should never close until that switch under the right side wiper is depressed when the wipers are 'parked'. If it does, the switch is bad, or the hoses are plumbed incorrectly, or the vacuum level is inadequate.
Old May 14, 2009 | 05:02 PM
DZRick's Avatar
DZRick
Originally Posted by lausbub92003
Say good by to the vacuum headache and convert to electric actuators. Look at www.ECPB.biz and see what you think about it.
Pushing your product a bit hard don't you think?
Old May 14, 2009 | 05:28 PM
bradc6's Avatar
bradc6
St. Jude Donor '05-'06-'07-'08-'09-'10-'11
National Champs Gators 4 St. Jude '09
In here and in general. Brought up every headlight and wiper door thread he could find.
Old Aug 16, 2023 | 07:38 PM
Boombastic Corvette's Avatar
Boombastic Corvette
Originally Posted by Alan 71
Hi Mike,
Regards,
Alan
Where's Alan?
Old Aug 17, 2023 | 10:05 AM
kansas123's Avatar
kansas123
He has been gone from the forum for many years.
To 71 wiper door
