Phantom White gauges
Old Jan 27, 2002 | 10:26 PM
Aaron76's Avatar
Aaron76
Default Phantom White gauges
Has any one out there installed these on thier c3 if so did you replace all the gauges or just the faces I have heard that you can just buy the face and glue them onto the existing gauge. but dispite my efforts I can't find a site out there that sells them.
Thanks for any info.
:crazy: :crazy:
Old Jan 27, 2002 | 11:18 PM
74-Roadster's Avatar
74-Roadster
St. Jude Donor '06
Father & Son St. Jude Donor '09
Default Re: Phantom White gauges (Aaron76)
I know there are a couple of members who put in new guages, not just new faces. One of the issues is what to do with the turn signal and high beam indicators. I like your idea of just replacing the faces and then maybe they could be modified. :cool:
Old Jan 28, 2002 | 01:50 AM
fauxrs's Avatar
fauxrs
I have installed Autometer Phantoms in my car - not just faces. So far as the turn signal indicators and the like you can keep the originals with a little creative wiring.
Part of my install included the Autometer Tri-Alert box which allows me to set warning lights to any electrical short sweep gauge. So Now I have a functional low Fuel level light, a high temp warning light and a low voltage light... The oil pressure gauge I installed is mechanical for accuracy so no warning light on it.
You can get the instructions for the install http://earchitect.50megs.com/corvette/gauge.htm - i wish there were more pictures of the install. Actually I wish there were any pictures, I didnt have a digital camera then.
[Modified by fauxrs, 9:55 PM 1/27/2002]
Old Jan 28, 2002 | 08:03 AM
GrandSportC3's Avatar
GrandSportC3
Cruise-In IV-V-VI-VII-VIII Veteran
St. Jude Donor '03, '06, '17
I put them Phantom Gauges in my Custom 68! I like those gauges much more than the originals!
You can get them at:
http://www.summitracing.com
Olivier
[Modified by GrandSportC3, 6:07 AM 1/28/2002]
Old Jan 28, 2002 | 11:46 AM
zwede's Avatar
zwede
Default Re: Phantom White gauges (GrandSportC3)
Olivier: Gauges look good. What did you do for the turn signal indicators and high beam?
Old Jan 28, 2002 | 03:45 PM
GrandSportC3
Default Re: Phantom White gauges (zwede)
At the moment I don't have a turn signal and high beam indicator. However - I am planning to put the
indicators into the center gauge bezel. I want to put the turn signal indicator where the seat belt/headlamp
indicators were. The high beam indicator I want to put where the seat belt indicator override switch was.
I really don't need the seat belt indicator or the hadlamp indicator (I don't have pop up headlamps)
In the last empty spot on the center gauge bezel I will leave the parking brake indicator.
I am very busy at work and don't have too much time to work on my Vettes recently!
Olivier
To Phantom White gauges
