71 Wiper HELP Needed PLEASE
I have visited old threads here and eventually replaced every part of the system. Switchs,relays,servos,vacuum lines etc. So I now know I have a wiring problem. Also I believed this to be a positve ground system & hot at all times thus working off of grounds to complete the circuit. Is this incorrect?
I just came across another thread that says the ground for the wipers often get mistaken for a starter wire and gets hooked to the battery terminal on the starter. I think this may be my problem and would explain why it is hot at all times.
Can anyone provide a picture of this wiper ground wire or any added input?
Thanks to all in Advance!
I think the link below may help you. I don't know why none of this turned up on your search, I have done multiple post on this the past two years.
Go read this and them post again if you still can't figure this out.
Corvette Windshield Wiper Motor Wire Schematic 69-72 with test
(This has been updated to correct schematic. Errors in the original GM schematic were carried over to our earlier version. Changes brought up in this topic lead us to tear apart our test machine and re-trace the wire diagram as it should be and not what is indicated in the AIM or other GM publications). The schematic on this test page is now 100 percent correct.
http://willcoxcorvette.com/repairand...elp.php?hID=95
Willcox Inc.
I have the cowl removed since a new windsheild was just installed. Also I bought the car with the wipers not working and an Invoice found in the car shows that a New York Manhatann garage attempted to repair back in 1993 and failed. So anything could have happen since then.
Since the cowl is removed I have the firewall switch bypassed and since I show continuity across the tach monuted vac switch I have that unpluged becaue I was trying to trace it out one wire at a time and I was getting feedback or power on both wires.
Is there supose to be power at all time with the switch working on the ground side to complete the circuit? Also how is the park cycle controlled?
The Wilcox diagram shows wire 6 (black/white) going to ground and wire 7 (black) going to the switch. That is the opposite of the way my 70 is factory wired.
I am also getting power on the blue and yellow wires which according to the Wilcox guide means either an incorrect ground on the wiper motor or a faulty relay or switch. I have isolated the motor and it works fine but when everything is plugged in it does not. I checked the motor ground and it is fine, I even ran a new ground to it, still have the voltage feedback issue.
Now have replaced the wiper relay just to be safe and confirmed it is wired correctly, still have voltage feedback. Just got a new wiper switch and will install that today to see if somehow that takes care of it, will let you guys know what I find.
I’ll try to explain some of this for you.
First make sure you are not testing with a volt meter and use a test light, if you use a volt meter the system will back feed voltage and use the meter as a ground. It will show low voltage at the wiper switch connection as well as the motor 1-3 connection.
The wiper system is not all that complex on your car.
The solenoid on the back of the tach from terminal to terminal will have continuity; it is just a basic electro magnet that operates a vacuum plunger inside.
So. . .With this in mind do the following.
Test the yellow wire for continuity and for a short at the 123 connector on the motor.
Test the yellow wire for 12 volts at the solenoid and at the number 2 connector in our diagram.
Next verify the ground on the motor. You can do this two ways, one is to run a new ground from the motor to the engine, or the other is to un-plug the ground from the motor and with your test light connected touch a hot wire and see if you light up.
Once you establish the black wire is a good ground or you run a new ground use this ground and your test light to see if you have power on the number 1 and 3 terminals at the motor. If you don’t light up, you’re good on to go on these wires so far.
Test the 1 and 3 green and light blue wires for continuity and a short. Test the light blue wire at both the switch and the solenoid and the green at the motor and the relay. If these two wires test fine the move forward.
Go to the relay, verify the ground on the relay, and verify the black wire from the relay to the wiper switch.
Make sure the ground wire is on the center dash cluster. If the ground wire is on, verify that the upper portion of the center dash bezel is not separated from the lower section, if the tiny area between the upper and lower section is broke, run a ground from the wiper switch screw to the ground terminal on the center dash bezel.
If the motor powers up on a bench, then there is no reason it should not power up in the car with the correct wiring.
If you verify all the wires in the system as I’ve described above with a bench tested motor you should not have any problems.
To answer your question, the motor is a two field motor, the red wire with a white strip is a hot all the time wire and the motor is hot all the time.
The parking mechanism is controlled by the motor pulling voltage off the motor power, so if the limit switch is open the motor will not park the arms on top of the wiper door.
The yellow wire is switched voltage and runs from the washer pump and wiper motor, to the bulk head connector, thru the fuse box, to the solenoid and then to the relay.
Buskey,
The schematic is correct; you’re looking at the connector from the wrong perspective. You’re looking at the connector in the wiring diagram from the terminal side and you have to look at it from the top side or wire side.
Willcox
My car has LB, BW and DB at the switch with the BW wire going to the relay (not to ground).
The configuration on the relay is the same, looking from the top or wire side. In other words, the BW wire coming from the middle switch terminal goes to position 6 on the relay.
All wires are still in their 40-year-old factory harness.....??
What you are saying is that your black and white wire from the wiper switch is running to the number 6 connection on the relay? (I guess GM could have had some different, I've not seen one that I can remember).
Willcox
Willcox
Don't suppose you have a picture of the switch connector plugged in so I can confirm proper blue wire orientation? I am missing the switch plug, someone had put female spade terminals on the switch wires and plugged them onto the switch.
This is really killing me......only thing keeping me from putting the interior back together!
Your post might as well be mine. My wiring configuration is the same as yours as I too noted the issue with the black wire with white tracer. My guess would be whatever is wrong with your car will be the same problem I am having. On your 123 connector on the wiper motor what color was the middle wire or starting from the closest to the passangers side going to the drivers side what was the color order. I beleive the last guy may have had moved these around inside the connector. Please keep me posted or PM me with any progress you may have and I will do the same.
Mr Wilcox
I thank you for your in depth repsonse and the time you have taken to give it. It seems to me I have gone through everything pretty much the way you described the process but still to no avail. I am going to print out your reply and go out to the shop and go over it one more time and report back
[IMG]
[/IMG]Test the yellow wire for 12 volts at the solenoid and at the number 2 connector in our diagram.
With test light I have 12V
Ground is good - Ran a new one
PROBLEM: I have power on 2&3 Yellow & blue but not #1
Test O.K.
Ground is good. Used a jumper straight to switch
Here is what Buskey was saying it is the same on mine. The white with black tracer runs from the relay to the switch NOT the black wire. It is not shorted and continuity is good
[IMG]
[/IMG][IMG]
[/IMG]Make sure the ground wire is on the center dash cluster. If the ground wire is on, verify that the upper portion of the center dash bezel is not separated from the lower section, if the tiny area between the upper and lower section is broke, run a ground from the wiper switch screw to the ground terminal on the center dash
I have had this problem on three different C3s. The switch was not grounded properly. In all three cases I just made up a small ground wire from one of the screws that holds the switch to the bezel to a good grouind under the dash.
Mr Wilcox
)! My thanks to Wilcox as well, I was totally lost without the diagram.Can't really help with wire orientation, just realizing that not only am I missing the factory plug at the switch, it's also gone at the motor. The wires at each are connected individually. Your pictures really help, at least I know the proper order for the switch. Not sure how to orient them on the motor though (except for yellow in the center of course), is yours correct in the picture or is that what you were asking me?
Just getting back to t-shooting again now......will let you know how it goes. It's 2pm on Friday here....too early for a beer??? I just realized that is a really stupid question.....
[IMG]
[/IMG]Update: While going through Mr. Wilcox's reply and re-running the test several times to be sure I am getting the correct results for no reason the motor starts running. It was going so fast I could not beleive that was a high speed selection but as I attempted to turn it off at the switch it only slowed down so I turned the key off and no change it continue to run and when I turn the key back on it goes back to 10000 RPM's. I checked the 123 connector while it was runing and there was no power at any of the three wires. I unpluged the relay and it just slowed down. I finally turn the bypass switch off and it shut down. Also as it was appearing to go crazy the washer pump randomly started and shut off and the drag of the pump caused it to slow sum but it would not shut off except to cut power from the red wire. This has got to be a result of previous attempt to repair this thing and perhaps a wire was spliced in the harness or another wire has melted the insulation off and burned into another wire causing the backfeed.
What is the possibility it is a bad motor? I am sure it was rebuilt in China or Mexico and the first 3 were doa. I have to keep walking away from it because I tend to have a bad temper and I afraid I may try to get even with this beast.
[/IMG]
[/IMG]
[/IMG]
[/IMG]
[/IMG]
[/IMG]
